Wifey Got In A Wreck Today! 08 G35
red00lght
Well, I'm relieved it all turned out with everyone ok. The G did it's job, but it sure got messed up from the little Mazda 3 that t-boned her! Might need to get her a Denali so she can see over the traffic better. We live in a really dangerous area with a blind corner and speeders rushing to beat the traffic. Pics....
My little 2 year old boy thought the car didn't look too clean...
I assume a total loss with just the pics...
Edit: Maybe $11,000 worth of damage. I cant see the underside so I assume a bent axle.
I would have to agree.... that definitely looks like there's more damage hiding behind things than there is showing. I'll be shocked if it ISN'T a total loss.
Ya...the rear spring snapped off its' mount, so it took a pretty hard hit! The tow truck driver (who also says he does collision work) thinks it is very borderline repairable....especially with 3 airbags being deployed.
I think I would push for a loss notice the torsional twist in the body - ie top of trunk line (trunk went two directions) and door (seam is pushed)- I know this is the impact area but looks like she twisted. I am willing to bet the unistructure has broken free underneath. I used to adjust and just from those pictures I do not believe I could recommend to an insurance company a compliant repair and then be held liable.
Hmmm, I am applying for an adjuster position...perhaps you should teach me a thing or two
moved to the off-topic. Not truck related.
Shop said they will most likely end up repairing this car due to the relatively high value of the Infinity. Even if the repair job is 15k....not what I wanted to hear but oh, well. At least the car did its' job so maybe it deserves a second life! :thumbs:
It'll never be the same. They may be able to make the body look normal but alignment issues, wind noise, possible water leaks just to name a few things to look out for.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
