Engine Hours
Just wondering what everyone's Engine Hours are, what is the average, what is high, what is low for certain milage points? 50,000 Miles, 75,000 Miles, 100,000 miles and beyond?
My Truck has 61,132 Miles and has 1,854.2 Hours on it.
  • Replies 65
mine was 62000 with 1750ish when i bought it, it's now at 80,100 and 2630ish
Bulletin for the hours resetting...My mileage 64063...hours 1879
IPC Engine Hour Meter Resets - keywords cluster DIC display hour meter intermittent start up #PIT4368A - (05/29/2007)2003-2007 Chevrolet Silverado Classic
2003-2007 GMC Sierra ClassicSome owners may comment of the ipc engine hour meter resetting. This concern may be very intermittent and normally occurs at key up and/or start up.
GM Engineering is aware of this concern and working on a correction. At this time there has been varying success repairing this concern with the following information:
<LI type=1>Check the battery/s with the Midtronic's battery tester and also perform a load test using a Vat40 or similar load tester to make sure the battery/s are in good condition. We have found in some cases a weak battery could cause this concern, this step is very important on vehicles with the 6.6L Diesel Engine where both batteries are used for cranking the engine. <LI type=1>Check the battery cables and make sure all connections are clean and tight. <LI type=1>Check the IPC powers and grounds (G200, G203, G100, G110 and the braided ground strap between the engine and cowl G104 and G107) connections and make sure they are clean and tight.
If the IPC has not been replaced, replace the IPC.
150,981 miles and 5122.4 hours on my 2003 Suburban... just checked it about 1 minute ago.
many cold cold winters idling...
    DroppingDiesel
    DroppingDiesel
  • Who's Online   3 Members, 0 Anonymous, 951 Guests (See full list)
