Jengland
I just got a set of 305/65/18 BFG A/T and I wanna thro them on. Its a 2008 Silverado 1500 4wd with a 2" level
I know it calls for 33" will fit. But these are a 33.6 they are worn down bout %40 Think they will fit?
Il be running a 18mm Offset rim
I ran a 275/70/18 on the stock 08 wheels with a 2" level and they fit fine. The 305/65/18 will more than likely fit but they might rub a little bit. Not an expert but you could probably trim a little plastic and be fine.
Gonna rub a good bit
If that's a positive 18mm wheel offset, they will fit but rub when you turn quite a bit. If it's a negative 18mm offset wheel... they will rub like holy hell.
Even if they're positive it won't work. I attempted to run 305/55/20's (a tad smaller than what the op wants)on a 20x8.5 with a +18 offset and it wasn't happening without cutting metal.
likewise
Not gonna happen without cutting. My 285's rub if I turn too sharp, even with a 2" lift. My tires are 32.8x11 and my wheels are +25mm.
