Ok i think its about time to change my transmission fluid in my 2001 Gmc Sierra 2500HD 4x4. What fluid would you recomend for:
Oil:
Tranny:
Rear Diff:
and ANY other fluid that comes to mind?
i was thinking ill use Mobil 1 for all 3 areas from now on but i would like to hear some opinions and maybe stories of what not to use and why or what to use and why?
My trucks about at the 50K mark so if anyone has some other tune up ideas that would be great too thanks, im thinking maybe plugs and wires or a K&N air filter?
Thanks!
-Kurt
um i know this may belong where you put it... but i dont want any random comments from everyone with 1500s and such... i want people with 2500HDs and 8.1s like mine answering this? so i really dont understand why you would of moved it cause the 8.1 is clearly a 'HEAVY DUTY' truck engine.... but whatever floats your boat i guess?
Well, theres your front axle and the transfer case. For the front axle, assuming yours is like mine, I would replace the fluid there with synthetic, the rear axle comes sith synthetic from the factory. Also, check your transfer case level, top off as necessary(Autotrak fluid)
Oil: Mobil 1 is good or any quality dino or synthetic oil of your choice. Buy high quality oil filter
Tranny: Dex VI synthetic edit: Double check with Allison. Prior to a certain year 2006, Allison my not recommend the use of Dex VI
Front Diff: Mobil 1 or Amsoil Severe Gear 75w-90
Transfer case: Should be synthetic trans fluid. Double check what the manual recommends
Rear Diff: Synthetic. Mobil 1, Amsoil Severe Gear 75w-90 If you have the G80 locker use no friction modifiers in the diff.
and ANY other fluid that comes to mind? Power steering fluid-synthetic. Brake fluid flush. Coolant flush if not done recently. Ditto on hoses and belts
Thanks!
-Kurt
I would check on the transfer case fluid. Don't think they run autotrack in the 2500's. I have 04 2500 with 8.1L/Ally and it runs dexron 6 auto tranny fluid.
+1 the 1500 and 2500 transfer case is different (1500 has auto). Check the manual it will state what fluid to use.
If you've got an '01 Allison 1000 then you shouldn't be using DexVI. There's an incompatablity with the transmission seals prior to a certain SN cutoff in 2006 IIRC. You should be using a DEXIII (if you can find it) or, a TES-389 (standard duty service) or TES-295 (H.D. Service) compliant fluid. I'd check Allison's website for the specifics: www.allisontransmission.com
Someone will correct me if I am wrong on this.
I live in a climate that sees -20F to +100F so I use synthetic oil and lubes in everything and I highly recommend them for use in either high heat situations or very low temps. Even power steering units.
I'm fairly certain your H.D. rig does not use Autotrack fluid in the transfer case.
DEWFPO
Here's what I was able to find. GM doesn't address it other than to say VI is backwards compatible. Two GM charts I looked at showed compatibility.
But, Allison does show this:
Effective January 1, 2007, General Motors no longer licenses DEXRON ®-III fluids.
DEXRON ®-VI fluids may be used in the 1000 and 2000 Product Families transmissions
beginning with S/N 6310670488 and 6320784373
So other serial numbers would be recommended to stay with away from VI. Mobil has their Delvac synthetic trans fluid that is Allison approved
If you have questions regarding fluid or filter change intervals, or models
not listed, contact the Allison Technical Assistance Center
at 1-800-252-5283.
intresting well i can say its a 2500 so it must have a 2500 Tcase and it is an 01' Allison so i guess it would use the DEX III.... im gonna look into if DEX IV is okay to use.... If anyone knows for sure what to use or what is best/preferred that would be great
thanks,
-Kurt
so lets get this straight....
Oil: Mobil 1 w/ Purolator One or Fram tough guard X6
Tranny: Mobil 1 Synthetic not so sure on which DEX to use?
Front Diff: Mobil 1 75-90? or is 75-140 better?
Transfer case: Synthetic obviously but DEX 3 DEX 4 DEX 6(wich one is/isnt OK to use)? or autotrack (is this gm's smurf stuff?) most likely i wanna stick with mobil 1 but whatever is considered to be best is fine
Rear Diff: Synthetic. Mobil 1, 75w-90 or 75-140? i dont think i have a G80 i dont believe 01's got the G80 no matter how much you paid idk?
Dot 3 or 4 brake fluid?
synthetic power steering recommendation ?
Also why not its only one more question.... preferable coolant?
and just to throw a random one what can i get for really blindly bright High/Low beam headlights?
75w-90 will be just fine for your diffs
I use Amsoil power steering fluid. Any good quality dino or synthetic will be fine.
If your truck has Dexcool in it, stay with it.
Brake fluid: Dot 3. Whatever good quality brake fluid your local auto part store sells
I'll stay away from a "blinding bright" bulb recommendation, because I don't believe in blinding other drivers. :P
Again, I'd call Allison's hotline # and ask their recommendation for fluid
haha okay i guess your right about the lights but i dont know i kinda like those sylvania Ultras 50% brighter :lol:
is 75-140 that much better cause i dont mind spending a few more $$ for something that can elongate my trucks lifespan.
is the dexcool the stock GM stuff? and would i have to go to them for more?
and i guess ill do what you say and give Allison a call or just go read my manual
thanks a biggie :P
-Kurt
haha okay i guess your right about the lights but i dont know i kinda like those sylvania Ultras 50% brighter :lol:Sylvania's will be ok. I run them. What I hate are the HIDs that are improperly installed and shining light all over the place blinding oncoming traffic.
is 75-140 that much better cause i dont mind spending a few more $$ for something that can elongate my trucks lifespan. I doubt you're gaining anything with 75w-140 Thicker is not always better.
is the dexcool the stock GM stuff? and would i have to go to them for more? Dexcool is sold at parts store, Wally world etc.....
and i guess ill do what you say and give Allison a call or just go read my manual Your manual is going to have information from 2001. Talking directly with the manufacturer you'll know for sure.
thanks a biggie :P
-Kurt
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
