New Look
thx to rich MS3DALE for ordering me the gm accessory black granite grill and the LTZ bumper, and to Steve for painting the bumper
I am happy with the look (minus the winter wheels)
In total it took 4 hours to swap everything out using hand tools....kind of a pain in the azz but pretty straight forward
btw nice to finally meet Chris (Kilo9)
WOW, those winter wheels sure are ugly!!! But, that colormatched front end looks good as hell, looks like you have the z71 appearance package minus the huge z71 stickers, of course. :lol:
the rims were cheap.....and its winter!
those are the ugliest rims... are they the GMT900 spares?
you could get some cheap steel offroad rims that would look better..
awesome truck though
gm take offs from trucks that get ordered with the accessory 20-22 GM wheels (same as spares)
for $170 with sensors for 4 wheels hmmm i could care less about looks for winter.....with the liquid brine glue shiat they spray on the roads in canada, alluminum wheels look like crap after one season
ohh wow. that is a really good deal. i think those other rims you have are the best looking GM truck rims without a doubt. but i hear they corrode easily...
Hey......Its the police truck!! :uhoh:
Looks good Mark! :lol: Let me know when your back down this way,We'll hit up Primanti Bros. again!
thx again
im dying to meet mrs Primanti lol
Looks sharp!
You must really hate winter? lol Here in central Texas its a cool 50* and sunny. :lol:
i like winter for december and a week in Jan around new years
after that it can kizz my azz
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
