Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok, I've been reading all I can about this issue, and it seems to me the combination of disabling AFM and using oil catch can when truck is still really new (1,000 miles or less) just might be the ticket! I really think old cow hit on it with his '13 by doing those two things right away.
Guy Gene,
FWIW: On my high mileage 2008 CC 4wd with 5.3, etc.: truck used to burn oil like they all seem to do. After reading up on the issue I went old school to confirm: I ran a compression check on all 8 cyl. (with AFM, I considered only checking 4, LOL). All cylinders were high and even, therefore rings were good. The topside was the culprit, I changed valve cover to get new PCV design and disabled AFM. No can was installed. ALL oil consumption stopped, like nearly zero. I do not have to add oil btwn changes, and its been like that for over 100K miles. I did not have to add "can", that seems to only treat the symptom, i.e. catch the oil vs stop the leak.
I have been very pleased with the 2nd life in the truck. She likes running on all 8 cylinders all the time, gas mileage has not changed, oil stays in crankcase, computer tweak got the govt out of the engine. She actually runs better today than 4.5 yrs ago when I got it with 99K.
Daily Driver - 353K
One thing for certain, I have never heard or read where anyone regretted disabling AFM. Virtually 100% positive comments when they do it. Mine was only AFM enabled for about the 1st 240 miles on the odometer. Been disabled ever since. I noticed an improvement right away. Smoother cruising and acceleration. Many claim a person can't really tell the difference, but I sure can.
Guy Gene,
Daily Driver - 353K
Now, that is the ticket indeed!! Just changed one valve cover? How ye disabled that AFM mess? I just wonder why in the world GM won't put the right kind of valve cover on trucks?!
I like cow's idea of doing whatever you do straight away. Stop the mess before it gets started!
  • 1 month later...
I have a 2008 Silverado LS 2WD with a 4.3L V6. It uses about 1 qt of oil per month. I'm reading through this thread now to see how people have fixed this. I bought the truck used so I have no warranty on it.
What is the part number for the valve cover and what tool did you use to disable the AFM?
I have a 2009 Silverado 1500 4x4 with the 5.3 iron block.
Can someone please post the how-to or info and part numbers?
thanks
thanks
The new left valve cover for the 2009-2011 AFM trucks is GM PN# 12642655.
There is a different PN# for the 2007-2008 trucks??
Alot of us are using "The Range" device to turn off AFM....
Edited by Bad Bowtie2
2007 5.3 Cast Iron with AFM. Around 50k miles. Average approximately 5000 between changes. Changed the oil around 40k miles, added one quart before the next change. The same thing happened after the next change. 1000 miles after my most recent change it needed a quart, added another quart today, after about a 1000 more miles. Information center says oil is currently at 55%. At this rate I'll use 3-4 quarts between changes, 10,000 miles ago it was zero. Taking it to the dealer as soon as I can.
This sounds like my 2007 Yukon xl. Excessive oil consumption started somewhere around 35-40,000 miles with about 1-1.5 qts every 3000 miles and now its at least a quart every 1000 miles. I now have 129,00l0 miles and had to have an engine flush last week after driving home it went from sounding perfect to a loud metalic banging that got louder as you accelerated. I had it towed to my mechanic and he sufggested the flush first and if that didn't work he expected lifter damage.
Edited by Farmingdales Finest
How to stop Oil Consumption:
1. Turn OFF AFM, this hair-brain system shuts down 4 cylinders for a virtually unnoticeable improvement in fuel mileage. This is to appease the EPA anti-oil folks that demand car companies achieve unrealistic standards. Turn off AFM and let your V8 run like a V8. Where do you think the saying "running on all cylinders" came from? I took mine to a speed shop that turned off AFM, when I asked the guy "so, what all did you do"? his response was "don't worry about the details - I just got the Govt out of your engine, it should run a long time now."
2. To be sure you don't have a piston - ring wear problem, do an old-fashioned compression check on all cylinders. This will let you sleep at night knowing that the bottom half of your engine is sound. Most problems are in the top half associated with AFM and the PCV valve built into the valve cover. (see above for part #)
3. Install the upgraded valve cover that has the new design that actually keeps oil where it should be and allows air back into the intake manifold, not oil. With the original design the oil blows out of the valve cover and accumulates in the valleys of the intake manifold. It then spills over into the engine as you ride, most noticeable at red lights on a hill.
I performed the above steps on my truck at 180,000 miles and it has run super ever since. It runs better today than it did 4 years ago when I got it at 99K. Oil change at 5K, Tranny fluid at 50K, all fluids, belt, spark plugs at 100k.
2008 CC 4wd 5.3 Daily Driver - 360,000 miles
HCG, did you install the 'deflector' inside the oil pan when you installed the revised valve cover?
My 2013 had the newer valve cover, but I still used a catch can on the PCV line and catch about an ounce of oil every 1000 miles with it. The oil deflector "improvement" that GM made might stop larger amounts of oil from getting into the PCV line, but will do nothing for misted, small particulate oil that is carried along with the crankcase gasses up the PCV line. This is an issue no matter the engine size, brand, etc. Not just a GM issue.
2013 GMC Sierra 5.3. 28,000 miles. Got check engine light and rough idle. Took to dealer and it was 2.5 quarts low and #1 spark plug was fouled. Doing a oil consumption test now.
That's too bad that a 2013 should already be having issues. My 2013, with roughly the same number of miles, barely uses a drop. I have 5000 miles on this fill of engine oil and the level has barely moved off of full. Been pretty much like that since I bought it. But then, I attacked the problem issues within the first 1000 miles like disabling AFM and installing a PCV catch can. Thing is, I really hadn't kept up with this stuff until I bought this pickup. Right away I started reading various forums, saw what was going on, and immediately started preemptive measures before the engine had time to go goofy.
05 Silverado 5.3 Z71 extended cab, lifter noise on startup I use dealer oil, basic mobile 1 blend I believe and I have to put a quart in about every 1000 miles, no leaks that I can detect so I don't know where it goes...157k miles right now on an iron block with aluminum heads.
Edited by kaleb b
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
