Go for it you will not be disappointed
(null)
You guys want to see a drag race of a NHT xcab 4x4 with BB tune VS NHT CC 4x4 with tune CAI ARH 1 3/4.He was was approx 5950Lbs i was 5800,he had tools and a passenger to get to that weight.Both launched in auto 4x4 and switched out at 60'
What were your times, that was an awesome video?
Maybe I am missing something but which truck was which?
Both 6.2? The other guy BB tune?
(Maybe I am missing something but which truck was which?
Both 6.2? The other guy BB tune? )
Xcab on the right.Crewcab in the left lane. NHT=6.2 3.73 (i know you guys all know this) BB tune = black bear tune.
This is my second run down a track since 1982,first one you already seen
Edited by gonzoid
I know what BB is, did the other guy have a BB Tune, that is what I was asking above.
On that day I had a waiteformepreformance tune (jesse bubb) have you heard of him?
Oh I was confused 2. I would have figured the xcab with the BB tune would have done better? Considering I have a BB tune on the tax return want list, I'm glad to see it was another tune.
Dont mean to sound rude but dont you guys see the headers hence the ARH or the cold air intake,did you not see the weight difference?thats why the crew pulled away.post #170 for the ET's and speed
I guess I underestimated the HP and TQ gains from ARH. The COI gains are minimal and because of the description of the trucks in the race, I just assumed it would have been closer. The CC won by .6 and in the 1/4 that's a lot. I would have assumed the BB tune and the ARH would be a push? Either way sweet video and thanks for showing us what our trucks can do.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
