The NHT leaf springs do have a different part number (as when I was having issues I looked into going that route). I have no idea what the difference is.
That's pretty much what I was saying in post # 222 but it's interesting to note that neither the Z82 nor the Z85 suspension packages show anything about any heavier springs. In the parts catalog there are only two different part numbers for leaf springs on 1500 series trucks (which I also find hard to believe but I can't argue with the GM parts catalog), NHT/HP2 and NON-NHT/HP2, that's it.
HP2 = Hybrid propulstion system.
Edited by ChevyTech77
2 questions about the transmission in our NHT trucks.
1st, is it any different than the non NHT trucks?
2nd, Is it based of the Allison transmission?
I have been told that the 6 speed transmissions in our trucks with the NHT package are more heavy duty than the standard 6 speed and that the technology in them is based off the Allison transmisson.
yep NHT 3.73 14 bolt,where did you find info about wider springs than non NHT? have info a link?
Sorry i do not have a link, i know the NHT and non-NHT springs are different as others have stated, i assumed they were wider. I hope somebody can chime in on the exact difference between the two.
Ryan, don't the NHT trucks have the tranny cooler, or do all the 6 speeds?
Mine has a tranny cooler, it was part of the PDU (power pack plus pkg). It was with the trailering pkg and 6 speed trans
Wondering why our 6.2s have the tailpipe going straight out under the bumper..is it because its a loud engine?..might make a person in a vehicle next to us uncomfortable? Lol..anyone know ??
Just to distinguish itself from others is the best guess I can come up with.
They sure sound tough at least to me. It seems to un-nerve the wife if she is anywhere close to the back of the truck when I start it. ( hehehe)..wouldn't dream of looking for an aftermarket exhast system for the 6.2 :)
Fewer bends in exhaust piping = freer air flow and healthier sound.
The helthier sound comes from bigger pipes, and the one less bend in the exhaust, while it is fewer, im sure has no effect on HP(or extremely minimal)
I'm pretty sure that the size of pipe was used for less backpressure but making a 90 degree-ish bend, right after the resonator, wasn't going to happen in that amount of space with that size of pipe, is my guess. And an educated one, at that.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
