I don't believe the 6.2L was available until 2009. Prior to that it was the 6.0 and I do know the 2008 did have AFM. I may be wrong, but I don't think there is any difference between the 6.2L from 2009 to current.
I have an 08 sierra denali with a 6.2. The SD in 07 also had the 6.2. The Denali/SUV/Caddy was the only truck to have the 6.2 until 2010 I think.
Is it the L9H motor?
You guys getting 12.5 mpg at 80 mph must be somewhere really cold, your truck is an NHT build or you have some mods done to it that have affected your mileage (tires/wheels/etc) because mine will still pull down 16 mpg flat at 80 in 35 degree weather but I'm just a Z71 and all stock so....... :dunno:
Yes, NHT, was under 25 at least, and leveling kit and 20s kill mileage with increased speed im sure.
The silverado's got it in 09. I did not know about the Denali having it in their trucks first though :thumbs:
No, it's a L92 truck engine that came stock in the Denali from 07-08 i know for sure. And it don't have AFM.
Edited by tmoney92
L92 was available in the Sierra Denali's only, from '07 to '08. '09 to current model year pickups use the L9H. Both are 6.2l but the L9H just has some minor intake and exhaust improvements in both the manifolds and in the cylinder heads. Both engines had VVT but no AFM. Only the 6.2's that were installed in the Yukon Denali's and Escalades had AFM. I do not, however, believe the L92's had E-85 capability but I can't find 100% supporting evidence for that claim either so......
Edited by ChevyTech77
Overview
The Vortec 6.2L V-8 VVT (L9H) is one of the most technically advanced truck engines in the segment, with features that include variable valve timing and E85 flex-fuel capability. The L9H's balance of performance and efficiency is great airflow throughout. Intake flow was improved by straightening out and optimizing the flow path from the intake manifold into the cylinder heads, while the exhaust ports are also designed for greater flow.
The 6.2L is the most powerful of GM's Vortec V-8s. It delivers exceptional refinement to go with brute strength, and advanced technologies such as cam-in-block variable valve timing. It was also developed for quieter operation, with virtually every system or component reviewed in an effort to reduce noise, vibration and harshness. Quiet features built into the engine are complemented by an improved engine cradle and mounting system. These help reduce vibrations transmitted through the chassis and into the passenger compartment.
I would expect the L9H to run slightly better due to its intake and exhaust refinements. Even the littlest change there makes a huge difference in overall power and drivability.
To bring the mileage back in, it sure goes down the more you use (let run) the remote start. My last tank netted a whopping 11 mpg! Got 12 in my 06 Z71 w/33's. My old 06' with the 5.3 would bog down and kick down into 2nd when going through the hills at 70-75 mph. Now, I just breeze up them without hesitation at all. Might kick down to 5th once or twice, but that is it. Love it!
All of our engines, 5.3-6.2, can haul the 10,500 lbs. The problem is stopping your truck! Making turns! That is when it becomes a scary ordeal that we have to follow specs for.
I cannot even get any of those other trucks to get on it when I am around! I did pull a 2011 Charger with just a plain Hemi, he was pissed. I do not think he could drive?? Then got spanked by a Magnum SRT8....oh well...
Still considering a tune, 6 mo. old, 2300 miles!
Thats about when I got my tune from BB. You won't regret it :thumbs:
Pffff, 7 months old now but has 9200 miles on it. And I only live 2 miles, one way, from work. Can't keep my hands off it! LOL.
:cheers:
So to recap,
L9H > L92
Wanna line up?! :driving:
Sure, there is a track about 2 miles from me (formally known as ORP)
2 yrs just under 22K miles here
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
