Just received my decal today. Thanks 2010LTZ4x4 & Ryan for posting the info for it. Peter @ Top Flights helped me and got me the emblem 4 days after I sent payment! That's fast! Looks great! :thumbs::thumbs:
No problem. :D
Acutally just ordered 2 more for the hood (same like Ryan)so when other truck owners pull up beside me they can see whats under the hood. :omg:
Pull up beside you. Really?? They are going to be behind me. I should have ask about a bigger one, that way they can see as I pull away! HAHA!!!!
I'm sure I'll stop on a 4 lane road some time while the light is red. :rollin:
Its a sticker. Let me look for the link
(null)
Cool. Where did you get the turn signal mirror?
Edited by 11Silvy
I got the turn signal mirrors From a member on the site (alaskaLTZ)
(null)
Edited by RyanbabZ71
What do you guys get for gas mileage with the 6.2 L L9H......and does it have the 3.23 or 3.73 gears? Just curious if I could find that info. I have a 2008 1/2 ton that gets about 16miles/gal (variety of driving)and am considering going up to a 3/4 ton with this 6.2 motor. Curious how much I'm going to impact my mileage.
First off, they don't make a 3/4 ton with the 6.2 L9H engine.
Second, I average 15-18 mpg depending on how I drive it. Lowest I've seen is 12, highest was 19.5.
Damn, you're getting better mileage than I do with my 5.3! :lol: I'm guessing my locking out 5th/6th gear in town is what kills me but it drives better that way.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
