How much would this cost
http://www.sporttruck.com/techarticles/0110st_horsepower_upgrade/index.html
Recipe Card
•4.3L Vortec block bored 0.030 over
•Stock Vortec iron heads
•Stock crank and rods
•Stock oil pan, sump, and pump
•Competition Cams: Camshaft PN 18-119-4 (high-energy flat tappet)Lifters PN 812-12 , Timing chain set PN 3200,Rocker arms PN 1412-12, Push rods PN 7812-12, Valvesprings PN 980-12, 1-inch carb spacer
•Edelbrock Performer intake PN 2111
•Demon 625-cfm Road Demon Carb w/No. 65 Primary jets, stock secondaries
•MSD PN 8597 Distributor, total timing advance = 34 degrees
•Peak horsepower: 222 @ 4,800 rpm
•Peak torque: 275.2 @ 2,500 rpm
I have a 4.3l just interested in thoughts .
http://www.sporttruc...rade/index.html
Recipe Card
I have all of that besides boreing the engine
and this
I have no idea what alot of that means . Basicaly maybe someone could go threw all of those part and tell them what they mean if they want that would be cool .
What year is your truck? I'd never go from fuel injection to a carb'd engine.
with 74,000 km . Basicaly a new truck still. Its worth nonthing anymore so basicaly going to keep it . This just seemed or might not be to much of a costly mod for basicaly 30 more hp and 15 more torque I could be totaly wrong tho. I like my little 1500 silverado 5sp its not that powerful but it can take a couple atvs up some gravel road . or a small boat on some lake and camping gear. I know i wont be towing anything big and I am fine with that . Its a easy truck to drive to . Most likely I probely wont touch the engine tho . This is going to be my 2nd vehical when I can aford a new truck . I am hoping to get a good deal on the 2012s when the new 013s come out on a new 4x4 1500 silverado.
You won't be happy with the trade offs that come with losing fuel injection. Not to mention in most US states a swap like that would violate emissions laws.
I think I have to do some big self educating on my self to understand what a cam actually is besides skimping on wiki what it is and why cant you have a cam and fuel injected .Most I am going to have to read what fuel injected is to. I guess . I was thinking this cam thing was just some metal timeing thing that was part of the fuel injected thing . So what are those older engines with the big filter things on them is that part of a cam set up ?
becuase i always thought those were a carbatore thing . Witch again i am not 100percent how those work . I thought somehow fuel injected engines replaced the carbatore engines . Well I know what i will be reading about now when i am boared .
you can cam anything.With fuel injection you have a the computer reprogrammed,carb you just tune the carb.Carb vs nowadays FI performance wise its damn near equal.I would personally drop in a 5.3L LM7 or a LQ4.You probably still wont be happy with the truck after all of the mods and money.
I think I have to do some big self educating on my self to understand what a cam actually is besides skimping on wiki what it is and why cant you have a cam and fuel injected.
Every motor has a cam. It's the part(s) that synchronizes your intake and exhaust valving. When folks say "cammed", they just mean a non-stock cam. Do *not* go from fuel injection to a carb. Actually... since you're not sure what a cam is, don't touch the motor :)
All I touch is the air filter , windshield wash, check the oil, and change it and the filter and battery . Looked at the serpitine belt looks fine . The rest of the truck is just a magical contraction that works lol . The only up grade I might do is just some helper springs get my dad to help me or someone who knows what they are doing . and some better tires that can handle more weight
If you are looking at building a motor on a budget for the most power to cost ratio, go ahead and jump up to a V8 build. If you want the uniqueness of building the 4.3 then go ahead and proceed. I have had several trucks with the 4.3. They are a great motor. You can do some low budget bolt ons to get more out of them, but if you want lots of power out of them, you will be putting lots of money into it. I'm not saying that this is a bad build, but to make the same amount of power as a V8, it will cost you more.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 568 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
