Changed the oil yesterday and today was family time so we went to church, lunch, shopping, a movie and finally some ice cream. Of course we took the truck for everything.
Truck hasn't left the garage since Friday evening after work
Went to a wedding sat night, drove in style :)
Ryan
Yesterday got the wheels back on my buick cleaned it up and put it out front for sale was gonna wash the truck but ended up going out to some mma fights with a friend, today helped my brother with his new truck and loaded up his old one on my friends trailer and sent it off to get the motor pulled. And played in my truck.
Sent from my truck using TAPATALK
Got my stuff out of the truck before it goes to the spa for a couple of weeks home it comes back all cleaned up!! :jester:
sold my beloved buick for $500 cash today.. sad day.. my boys dropped off my brothers truck after taking the engine out.. want to wash my truck but too damn lazy
When and saw my baby all apart at the body shop:( They are going to put on the roof panel to many dents to get out but they have got all the parts in, big hold up will be paint. :jester:
I drove my truck home, opened the garage, then started a complete tear-down/resto on my dirt bike.......... inspected the truck too lol
Picked up 8 ft of 1.25 square tube to make a cb antenna mount
Sent from my ADR6400L using Tapatalk 2
Drove my truck to my favorite auto parts store today to order the Corsa cat back for it....should be here tomorrow...................is it tomorrow yet?, lol
I'm going to try and take the old exhaust off in one piece, a member on here said it can be done so we shall try.
Edited by sixathome
What store?
Tomorrow and Thursday I get to go downtown to a training/team building event for work and valet park my truck. This should be interesting :( Since it is a pretty nice hotel I figure they will have decent people working there.
I got my CAI for the camaro today. WOOHOO!
got my tail pipe welded back in place all level again, then went and checked out my buddys s10
Drove back from Urbana, IL where I've been since Monday. Almost driven 20,000 miles since March.
What store?
CarQuest.
Got it installed tonight. It went good except for the flange bolts snapped with not even 30 ft-lbs of torque :( so I had to drill them out...ugh. I got the touring system, single exit. It's a little deeper sounding than stock at idle but a lot more robust when you get into the gas, just what I wanted.
    • Hit mid 90's today. Even at the boarder of Canada and up by Duluth it was in the 90's. Going to be like this all week. Sure it's nothing like the south seeing 100's but they do say it's a different kind of heat here with all the lakes/water and humid days.
    • Pill flip on the transmission cooler lines is a 100% must do thing too.
    • It's a '21 and was a CPO with extended protection when purchased, so hopefully it will be covered.   I supposedly have all of it's service record history and nothing noted other than routine fluid changes, tire rotations, and the windshield washer nozzles replaced once.
    • I would argue that GMPartsDirect has that info wrong.    The service manual for R+R the lower arm and for adjusting camber/caster, none of the steps say to discard and replace the nut or the bolt.    The only part that gets discarded is the plastic cam adjustment retainer that is in the eccentric from the factory.     The LCA nut torque spec is:  First Pass: 180 Y (133 lb ft) Final Pass: 90 –105 Degrees   That is WELL past 130ft.lbs per the TSB that you reference that does not apply to this scenario.     As for your clunk.  I'd say it needs to be diagnosed thoroughly.  Assuming the LCA hardware is tight, you could have a problem with the UCA, sway bar end links, etc.
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. They read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post. Trending is very important.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
