Mine is a SuperStart or something like that, I was worried it would go last winter, but it's still "crank crank vroom" everytime. It'll sit for 3-6 days at a time this winter, I wonder how bad that is for them...
I think I'm going to go with the top shelf autozone when it needs replaced, as it has top terminals in addition to the sides for easier jumping.
+1 on the Duralast from Autozone. Bought one a few years back based on a Consumer Reports ranking, and it fires in a hurry, at 100 degrees or 20 below, hasn't skipped a beat in almost six years.
Repaired my DRL/turn signal/marker light housing. I knew moisture has been getting in but when I removed it last night to replace my DRL bulb it was flooded, probably shorted the bulb. No real damage and socket still works but sealed up the housing the best I could and let everything dry out over night. Also after a battery disconnect reset I may have fixed my non responsive coolant temp gauge. So far so good.
Did a 730 mile drive today from Bakersfield, CA to Layton, UT. 10 hrs 45 mins behind the wheel according to the DIC
thats good time
Sent from my ADR6400L using Tapatalk 2
That was behind the wheel time. It took like 13.5 because I screwed around in Vegas and Mesquite, NV. From Bakersfield to Mesquite when I filled up I got 17.9 MPG. From Mesquite to here in Layton I got 18.9 according to the DIC. I haven't filled up yet. I still have a 1/4 tank.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Still good, i did 750 took 12.5 drive time, made a stop over night to sleep 1/2 way. But it was worth it weather is great here in myrtle beach. I was happy to know i avg 18.2 in the mountains of wv
Driving what? I have a 2wd 4.8 that's tuned. A leveling kit that "supposedly kills aerodynamics, 3.42 gears and 20's. I would have loved that mileage the whole way there
Switched from summer tire/wheels to winter/gone hunting ones. OE polished/Michelin LTX AT2 - OE steel/Duratracs
Edited by Portdriver
11 1500 4x4 crewcab stock 5.3
Wow and I'm getting damn near what you do with AFM and a 6 speed. But your truck is a 4x4
I did 900 miles this summer going back to NH and it was like 14.5-14.75 hours. Same going home and that was taking stops to eat and not really rushing.
Yea it was about 12 total. I did some gambling in Vegas ans Mesquite
found some really awesome two tracks and wide open trails definitely going back to check those out completely soon, and hung out at my friends place for the evening
Went to the pumpkin patch today
New BFGs are great in the mud and sand
Ryan
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
