Happened to me quite a bit late last night. Tow mirrors magnified the problem of them doing it. Having bright brake lights helps return the favor
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Drove up north last night
Some jerkoff in a small BMW decided to fly up behind me then hit his brights. Funny thing he was so close it didn't bother me and it flashed right off the tailgate back at him haha. Finally was able to get over after he flashed me a second time well I got behind him and hit my brights (oh ya my fogs were on too) lit his car up like an Xmas tree.
Please when the speed limit is 70 and traffic is going almost 80 don't flash your lights at people usually it will backfire on you especially if your in a small car
Ryan
I agree, whats wrong with people? My drive to work is part a st route, its 45mph 4 lane. I have been flashed while going 60 in a 45, only makes me go slower. People need to give them selfs more drive time!
Sent from my ADR6400L using Tapatalk 2
Cleaned up the engine compartment while it was nice out. Temps are supposed to nose dive tonight into next week. Another winter on the dock, hooray!
Edited by SILVERADOSC540
Damn truck has to sit outside for a few days as we are visiting family :(
Ryan
Edited by RyanbabZ71
I get pissed when I'm in the passing lane unable to get over and someone's riding my bumper I slow way down until they try to pass on the right then I punch it
IDK, I was taught if you r not passing, get out the left lane. Nothing worse than people just sitting in the passing lane. I don't care if your in a truck and think you are special or not.
Sent using Tapatalk
Sent using Tapatalk
I was passing that was one of the main issues I had with the situation
Drove home from work, ready for long weekend.
Seen this truck on the way homeury4esu7.jpg that thing has one heck of a stack! Didnt sound to hopped up tho
Pickups trying to be big rigs with 1 or 2 stacks in the bed crack me up... Truly a terrible look.
Rippin across Michigan to caro 3.5 hour drive can't wait to roll through ghetto Saginaw
Edited by SarahsGMC
Don't get murdered! lol
You know her better than I do Mike but from what I've read and gathered about Sarah I'd worry more about the other guy.
You've never been to Saginaw I see
Not recently, but a bit of quick research gives me the impression that it isn't where I'll plan my next family vacation.
105 octane
Ryan
Can't run ethanol, full boost will have to get me through the city. Sarah can just use the new light bar to clear a path.
Parts of Saginaw aren't all that nice a place to be. I have my carry permit and I wouldn't go there, Flint or parts of Detroit without a damn good reason.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
