Washed the truck and changed oil tonight
Ryan
if i raced you with my 4.8 i would kill your truck, i would be about 3 car lengths ahead the whole time, idk if ill get traction off the line though, i have way to much power
Just keep it out of 4WD at the launch, at least give me a chance...
Just got it installed and did the crank relearn. I don't know how to describe it. It's a lot better. The words my brother used were "It's like sex and cocaine", I feel a lot more power and it makes me smile
Strange, back in the eighties I could never really make those two things work very well together. You'll be happy with all that power for a little while, that's when the cocaine and sex deal turns into a crack addiction and you just want more.
I put the 6.0 in and I want more.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Driving the truck after I reflashed stock for the 87 incident and.uggg......can't get through the tank fast enough.
Returned bottles.
Then I attempted to get my knee bolster off. I gave up because I'm unsure of where the clips are situated. I will experiment with a yard truck at work hahahaha
Sent from my Nokia 5190 using Tapatalk 2
Wait, why did you need a crank relearn?? The shop that did the install never did that for you??
He has no clue :lol:
Ryan
Nope and he is missing out on ALOT! I remember test driving mine, and thinking omg this is amazing. Even the sound of the engine at WOT is amazing. Sounds like a Camaro.
Lmao! Funniest thing I think I have ever read on here!
Ma'am your husband told me to do it so I did.
Justin said that could be the cause of my p0300.
And Jenna remember I said I don't like dealing with that shop. I don't know what was done aside from them giving me an LQ9 and flashing my computer so it will run
Edited by chawkins6789
Ryan
Some people can't afford a new truck. I can afford to add power over time
And who would that be?
I got you both beat. I make $3600 a month tax free and all I do is go to school one day a week. I sleep in til noon every day. The only thing I have to do is pick my brother up from school, and go to school Tuesday nights
oh-no-you-didnt.jpg Edited by SnakeEyes 325is
Ryan
There are used ones out there
Ryan
I can turn off traction control. Truck does burnouts just fine like that. :lol:
Yeah and then there are used 800's for much less, with no TC nannies, which I'm sure Chris appreciates. :lol:
Which does make them run better IMO. I think my 05 5.3 ran better than my 09 did.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
