going to check out a 79 k5 blazer today...wish me luck!
Always liked the K-5's. You have a link from craigslist by chance? Would like to see what the beast looks like!
It's only had 2 owners. Paperwork on everything done to it. Has locking hubs,350,auto trans, very little rust. It looks to be in dam good condition to, might be able to get it for 3k
Sent from my smartass iPhone using Tapatalk
I'd skip headers and just drop in a 6.0. That kind of power will really make that beast come alive. I'd dig up the thread on BBP's blazer.
With a 6.0, he will really want headers then.
Quite upset that I don't have my truck still
I don't have 4wd still. Gonna suck when I get into a situation when I need it and don't have it lol
This picture is a couple of weeks old, but I am new to the site and have not really done anything with my truck recently.
Hauled 4 loads of fill dirt. Good thing I have the air bags.
Talked to the guy I deal with at the dealer. Quoted me 880 for labor for them to pull and install front diff. as well as tear it down and rebuild it. That is not including parts. He then quoted me 600 if I brought it in and they rebuilt it. I think I'm just gonna let them pull it. I'm tired of.getting under this truck. And if it messes up, then it will be under warranty and I won't have to pay again. Learned my lesson, and it cost me probably $1000 plus the cost of this rebuild. Geezz...
Trans is fixed for now... But those couple times I drove it bypassing 2nd messed up the 3rd gear clutch and some internals so it needs a rebuild yay!
I'm looking into buying a used low mile trans from this reputable place he referred me to I'll see what they have and have it built up if not I'll have him rebuild mine. But the plan is to drive it until February and use my tax return to go all out on it.
Ouch! What happened the first time?
Shop I went to first time didn't set it up correctly and kept telling me it was different things, and I kept believing them at first. So now I have new front hub bearings and replaced a tcase just for fun lol
...the plan is to drive it until February and use my tax return to go all out on it.
If you're getting a significant tax return without owning a home or having children, you're paying too much in taxes. Fix your withholding level and stop giving the feds an interest free loan and spend your money now instead of in February.
In California this week. Visited a Tesla and a McLaren dealer today. This is the engine from a 12-C:
Where in Cali are you Mike? When Zane, Josh, and I went to dinner Thursday night, we saw a 12C that was a company car
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
