Finally got around to adding some underhood lights Ryan
How are they wired Ryan?
To the main power 12v (trailer wiring) to a switch grounded to a bolt.
Ryan
Ryan, your eyes would be bleeding.
I saw a ZL1 absolutely covered in Road Salt residue. They haven't put road salt down in over 3 weeks.
The ironic part??? The guy was at a "100% Gas" station. Yeah, he will pay an extra $2 for real gas, but won't pay for a car wash.
Wow, I actually took mine out today before we get tomorrow. I got my freshly cleaned wheel wells dirty :(. What color ZL1? I seen a new Red C7 today. First on the road cool car
Ryan
Who pays for a car wash? Lol - oh I fixed a broken ground wire.
My neighbor has a new Vette, black in color, not sure what trim level or what not it is
Sent from the side of the road...
There is only 1 trim level currently with a few options
What color are his calipers?
Ryan
House cleaning and snow plowing. Getting all ready for tomorrow as that should be my Ford/Gm 6.2 max trailer head to head test drive lol.
Sent from the Great White North
Wow, I actually took mine out today before we get tomorrow. I got my freshly cleaned wheel wells dirty :(. What color ZL1? I seen a new Red C7 today. First on the road cool carupepuvaz.jpgRyan
Blue Metallic
How do they look in red in person?
Edited by SnakeEyes 325is
Pretty good had black rims and red calipers. Not a fan of the exhaust setup so that's my only complaintRyan
Here is a photo of the light outputu2uvysuj.jpguhegate3.jpgRyan
Hah beat you guys! I saw a C7 over a month ago! Was red and looked awesome.
I have seen them too (on haulers) just none on roads by actual owners
The first one in the area was sold to oh man can't think of his name offhand. He won the indy500 this yr paid 20 grand over msrp from what I heard
Ryan
Edited by RyanbabZ71
Beat you, touched a c7 at SEMA
Hah beat you guys! I saw a C7 over a month ago! Was red and looked awesome.Beat you, touched a c7 at SEMA
Actually touched 2 at camaro fest august 1st blue and maroon Ryan
And to top that the day before the 500 in May we got to see it and take pics with itMy dadve6ujezu.jpgRyan Edited by RyanbabZ71
Yea well I watched some 14 Chevys roll out of the plant today
Sent from the toilet
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
