yea still a layer left on. Needs a good wash down, just hot water will not take it all off
Well as luck would have it, I broke the hard line for the washer tank. I may have to get a new one, or I think the 1/4" poly line that we have at work may be the same size. Grab a quick connect union at work as well and all should be good
Sent while drinkin' a cold one...
Let's see.... Today, I went to Line-X and got the bed sprayed. Then I installed my Fold-a-Cover tonneau. Then installed my GM led cargo bed lights.
Tomorrow I'm going to change the oil - only have about 1200 miles, but like to get rid of the break-in junk. Plus Advanced Auto Parts has a BOGO on Mobil 1 Super Synthetic - getting 10 quarts for $37 w/ tax. Will pick it up at the store tomorrow.
Just rammed into a girl leaving walmart truck was not stopping at all and of course the light was red so I bumped her.. truck took no damage lightbar saved the day again. Busted two lights but they still work lol. Didn't get in trouble either because they didn't want cops involved even though i dented their blazer and busted the tail light.
Sent from the toilet
You faired better than ironman tonight
Ryan
16 of them are in Indy. Took my 4 yr old to see em. Fun time
I am also a proud new owner of 2 copo camaros
Ryan
Monster Jam is in Little Rock also today. Grand son asked to go but he waited until today to ask and I did not want to sit in the nose bleed section so I told him to ask before the day next year. :jester:
Monster jam was here recently
Edited by SarahsGMC
I believe monster jam was here this past week or last week at the Verizon center in Washington, D.C.
Went to the gym/home depot and out to dinner. Big 35mile day in the truck; loved every mile....just over 1500 now.
Sent from my DROID RAZR HD using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
