Ryan hows the reception with that antenna?
No issues thus far same as the old one from what I can tell
Ryan
Ryan
But you're fairly close to Indy aren't you? I pull my radio from Ann Arbor or Lansing which are both like 40 miles away.
most of the radio stations are not in Indy but in the surrounding areas so its about the same for me.
How much was it
sent from my truck in a field
Edited by SarahsGMC
Some of the reviews on Amazon claim that the 99-06 antenna is different and the 99-13 stubby won't work, is that true?
when my tax refund comes in i should be getting my 6 inch lift ! Next up is trying to find the money for some 37s !!
Gonna need more than 6", trust me
Why 37's? 35's or 33's do better just cause the truck doesn't have to work as hard to turn em.
Washed it hahae3ygugup.jpgHelped my brother change his headlights in his 08 Malibu. I would like to have a civil conversation with the design engineer on this subject. Remove the front bumper really what the f were you thinking. The dealership wanted $200 to change the bulbs a5u7yda5.jpgRyan
Wow I tought pulling the wheel liner halfway out of my Mazda was stupid. Not that stupid I guess.
Changed oil, great time of year 20 degrees out
Ryan
Gonna need more than 6", trust me Sent from my SM-N900V using Tapatalk
Got a brand new 3 inch body lift sitting in my room at home!
Why 37's? 35's or 33's do better just cause the truck doesn't have to work as hard to turn em. Sent from my iPhone using Tapatalk
Because i know when i get 35s im just going to say i wish i got some 37x13.5s ! And because i want to have the biggest truck :)
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
