Do you know the history of the JSF program? We aren't talking about the Stealth Fighter or the SR-71.
It was a complete mess, way over time and budget. Chinese hacked the Pentagon, stole the plans, and have what is essentially a Chinese fighter believe to be on par(maybe better since they know our secrets) that was designed, built, and put in the air a good 5 years before the JSF planes were on a comparative scale. When a Telegraph spy photographer somehow got a photo of the Chinese plane taking off for a test flight over 2 years ago, the Pentagon admitted their intelligence said it wasn't going to be flight ready for 3-5 more years. F35 was supposed to be in service years ago, and there is a whole conspiracy movement about Lockheed not getting the bid to build their version.
Its a miracle the plane turned out that good, but then again that is compared to the F16 which is pretty old by technological standards.
Its kinda scary how the US was SO awesome and advanced with the SR71, F15, F16, Stealth planes, and then the next generation there is so much crap going on no one can get the dang things built.
Some bureaucrats decide the money was better spent on server farms to violate civil liberty than get the military the gear it really needs.
I thought the F-22 Raptor was replacing the F-16? What I miss?
22 was to replace the 15. 35 was to replace the 16
I live no joke across the street from Quantico MCB's training grounds for their jets. I remember I looked up one time and I swear a jet was so close that it was about to touch the trees. Whole house shakes too lol
Sent while drinkin' a cold one...
Ohhh okay. I see.
There are three variants of the F35, one is VTOL capable to replace the Harrier, one replaces the 16, the other replaces the F-18
No way is china's stolen design on par with anything we've done. Those crooks can only build good stuff when a western nation is overseeing production. It's like when you see the knockoff F150 made there. Looks exactly alike but it has a small engine with laughably pathetic output. No doubt just about every modern defense program is bloated all to hell but china will never build anything of quality on their own.
It will be better as a kamachazi plane
Ryan
I just washed her on Sunday but my front wheels are already slightly dirty from the darn pos pads! I can't wait to get the new pads installed and get rid of the dust and screaching.
Wash clay and wax finally a good day for it. Truck looks beautiful but I locked my keys inside while waxing the roof. . Soo now I'm waiting on my friends dad and his kit... could this week get any better?
sent from my truck in a field
I got up at 5 am to take a bull to get transformed into a steer. Surprisingly the truck got 13.7 mpg while pulling the trailer.
Picked my truck up from the dealer last night after haveing new carrier bearings and all new seals put in my rear end. Thanks god it dosen't sound like a half track anymore.
Ok should I be worried about this:
My old driveshaft is the big one. The new one I got is smaller in diameter but the slip yoke and length and u joints are the same? Am I gonna like break this new one or should I be fine? It came from an 03 silverado extended cab short bed 4x4. Did z71's come with bigger rear shafts or did GM just decide to change the diameter?
I doubt the Z71 would have been bigger, seems like that would be cost prohibitive during GMs cost and corner cutting heyday.
:lol:
Compare part numbers. Plug them into gmpartsdirect.com
Some dealer parts departments will also help you out if the above doesn't work.
Edited by SnakeEyes
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
