Won't ask as my cousin and I have driven a riding lawn mower into a lake
Ryan
He was to busy talking to me and rather than drive around the pond he tried backing up and just veered off the road into edge of it. and sunk it lolol. Ill see if i can get a pic up one minute!
Installed HID's highs on my 02
Low beam only
High and low beam
Sent while in 'Murica...
Edited by rdnckhntr94
That looks a lot like a normal halogen beam pattern. By hid's do you mean just the bulbs or did you go the whole way with new projectors, lenses and ballasts?
It's in a standard halogen housing so same beam just way better lighting. The lenses aren't stock but close to it because they are cleared (don't have that dispersion pattern on the lense itself). Crazy the amount of light these things are putting off while driving.
I also did low and high beam HID's in my '14 as well as led fogs for color matching purposes
Doesn't that just mean that you're blinding everyone? There isnt a cut off with a halogen housing and that type of bulb.
There isn't a distinct cutoff but with regular housings the beam "stops" like a projector would. It more or less "fades"
Edited by kstruckcountry
Gave her a really good scrubbing down. First time I've washed it good since buying it. Sadly noticed some deep scratches on the rear fender that I didn't notice before when it was dirty. Oh well, life of a truck.
Most roads I drive I don't have to worry about people coming the opposite direction. It's either really early in the morning or really late at night so not too many out and about at those times
Driving a truck is the only way guys notice me
We need to have a talk.
Drove it again after a week of sitting. So much better than driving the van :)
Ryan
Edited by RyanbabZ71
You've been driving the mini van, hahahahahahaha, all that horsepower in your garage and you drove the grocery getter. Lmao.
Sorry couldn't help it.
Yea for Xmas we took it. It has the 3.5 V6. We had it filled pretty good. Plus the 22 mpg isn't bad either. Need to rack up the miles so I can convince the wife into a new vehicle (non minivan). I do love the power slider doors thought
Ryan
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
