I'll be lucky if I even make that at the rate I'm going ....
Yeah my driverside front seal start leaking, replaced both at 694k.
Did you replace them yourself? I'm thinking about dropping the diff and doing every seal on it.
Sent from my SM-G920V using Tapatalk
He got a "Monday" truck ...
Miles: 235,846
Completed today:
Fram Toughguard air filter TGA8755A
New radio tune button
Right rear exterior door handle
Topped off engine oil - Castrol 5w-30
Upcoming:
New right side license plate light wiring + both bulbs
Oil is at about 3k miles but it has been in use since July. I think I'll go to 4k miles on it...
Edited by white1500
WTF you doing on the roof?
No, payed to get it done.
Is that a turquoise fire hidrant across the street?
Changed the passenger side driving light/fog light. Suckers are expensive. Then found out autozone had it $8 cheaper so went back the next day and had O'Reilly's price match it. Still cost too much but oh well.
So, remember the new suspension(everything but springs) I put on in July? One of the air shocks sealed dust boot is frayed and decayed. It looks worse than the one I pulled off with 8 years and 125k miles. On phone with Amazon trying to get a warranty replacement. Having a lot of trouble, being told they won't past 60 days, but isn't this clear that THEY will replace it? Ac Delco warranty is 24 months 24k for air shocks.(Amazon page erronously lists 12 months, but still it's been 5/12 months!)
From Amazon returns and refunds page:
Automotive Items
If you have purchased an automotive item shipped from and sold by Amazon.com that is defective and is covered by a manufacturers published warranty, Amazon will either replace the item or refund the cost of the item for the life of the published warranty.
Edit: without saying she was wrong at first she said they will be able to replace it after all, but I'll believe it when I get the email. I have been "approved" for a replacement before and their were just lying to get me off the phone
Edited by SnakeEyes
21st century "quality control" for ya right there. :nonod:
Friday night service calls suck. Heater went out in one of the rentals
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
