Be glad it was just a ding. My dealership just about totaled mine when it was in for the 4th or 5th warranty brake job, and to fix interior squeaks and rattles for about the same time.
Their lot tech drove it into the bay, and crushed the passenger side from bumper to bumper. I only found out about it after not hearing from the dealership for an entire day. I called, and asked, "Why is it taking so long for a damn brake job?" She says, "Oh, they didn't tell you?" .....
OMf'nG .... :banghead:
To top it all off, when I got the truck back, I parked it in the sun when I got home, and it looked like a 3D movie! Swirl marks jumping out all over. Had to bring it back and have someone with a clue buff it out. Never seen anything so bad in my friggin life!!
Filled up today and got a shock when I clicked over to the total miles screen
Ryan
Ryan
That thing is still an infant.
Ryan
What is the highest mileage car/truck you have owned? It really isn't that scary. Edited by SnakeEyes
That I have personally owned would have been my 2000 impala I bought back in 04. I sold it with 115K i think. My truck is second at 89K (owned for 9.5 yrs).
My truck would probably be at the same mileage if it wasn't in and out of the body shop for the past 3 months
I still have my idatalink, I would have let it go for cheap.
If i knew that 3 weeks ago it would have saved a few bucks on this birthday install. Was it the Rr?
Also im having an odd overheat issue. Havent got it above 236 yet. Gets hot with grille assembly on, take the entire assembly off and everything runs like normal
Billet grill? Can't run mine in summer pulling too restictive.
Yes. No one here ever responded to the ad, I kind of forgot I still had it until I read your post.
Found why my fans arent working
a7f0080bd42a11b71fcd226cb291622b.jpgI still had the harness from when the relays melted so i grabbed the fuse setip from that
    • I never understood the hate for the column shifter. The console shifter just gets in the way, takes up prime cargo space and in my wife's Jeep, the dog constantly bumps the console shifter into neutral!    Best choice ever to just make it a column shifter across the lineup and be done with it.    (Bonus: Makes swapping from a 5 seater to a six seater far easier)
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
