What's wrong with the LEDs? I'm going with regular bulbs again.
Hot spots and way too bright in certain situations
Ah I thought that's what you might say. That's part of the reason I'm not switching to them.
Had them for 3 years
Do you have a white face cluster? Edited by Daryl Z71
What I find really fun is someone recommended turning out the mirror when those bright ass lights come up on the vehicle.
I have been doing this and some of the vehicles dive onto the opposite shoulder blinded by their own damn lights.
Up here in MN we had -20° last night so I decided I should warm up the old girl. Straight off had a completely dead battery, only two years old go figure, but I got it charged up ok with the little charger I got ... and well, first drive since the Sunday before Thanksgiving, so that's 4 weeks it's been sitting. I had the truck warming up 15 minutes before driving around, Took a drive and just around the block the temp gauge starts climbing up past 240. I just get in the garage and the gauge reads at 260, and the DIC displays coolant temp very hot. I get it shut off, pop the hood and check around. Slowly release some pressure in the coolant overflow tank and see it start to drip out the vent tube. Day didn't get much better after that, got the snowblower out shortly there after to clear out in front of the garage and it starts pouring gas out around the carb.
Actually there doesn't seem to be anything wrong with mine other than half the bulbs being blown out, but I want the whole thing rebuilt anyway. Probably going with blue needles as well, and also having them add a transmission temperature gauge.
odo-pro.com
Edited by swampfoxjr
Carb Needle stuck or not closing properly. what kind of blower?
That's why I grind the lens flat, to eliminate hot spots. Plus you can get LEDs with lower mcd.
Edited by Coby7
After all, just my opinion. But for the $$$ everyone spends to get a cluster with transmission temp and get it programmed, they could get one of these, that can pull codes, show up to 8 parameters, and even be used on the next vehicle.
https://www.amazon.com/gp/aw/d/B00ZDNI8Y4/ref=mp_s_a_1_1?ie=UTF8&qid=1482167493&sr=8-1&pi=SX200_QL40&keywords=edge+insight+cs2&dpPl=1&dpID=41XV8e3LRoL&ref=plSrch
Also, some of the gauges (coolant temp) give a dummy reading and a monitor will give you actual readings. The touchscreen model will run a camera as well.
Sent from my SM-G920V using Tapatalk
Just had a great demonstration of that minutes ago.
Did a t-stat on a '06 Impala, 3.9 - after I burped what seemed like 10k cubic feet of air out of the thing, the factory cluster gauge came up to the center, where it normally stays. Scan tool showed 170°. Drove it around, stopped, turned heat off and held it at 3k for a minute, then shut it down, and turned key back on. Hot soak got it up to 222° on the scan tool - the gauge had moved literally 1/16" from 170°!
I'd prefer a little more accuracy than that on my dash gauges, that's for sure.
Edited by Jsdirt
I've been doing this for a few years now. I don't think it works well with the dually now though. Then again I have aux lights in the rear, great success turning those on and getting the turd muffin behind me to turn their brights off. :-D
I would probably do that if I didn't need my bulbs replaced too.
Just bid on a new Candi module for my TechII, hope I get for cheap. My candi module has been intermittent for the pass couple of months and this morning while trying to do a FOB for a Malibu it crapped out. Luckily it worked long enough for me to program the FOB.
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
