Every time I have to haul cars through NY, I see more cops along the highways there than even in MA! It's insane - usually see a trooper in every other u-turn access point in the median. Just one big revenue generator, as if the $40+ in tolls they charge me pulling my flatbed isn't enough ... :nonod:
I hate the Northeast!! This place will bleed you dry ... :throwup:
This morning, my son and I cleared the tree trunk sage brush from the front lawn with the use of my truck.
I don't even try speeding anymore in areas I'm not familiar with, it's not even worth the hassle.
Just sat in it trying to learn this horrible interface to the Nav system. Will probably buy a Garmin.
I miss living where that stuff grew!
Opted for a truck wash.Automatic version. scrubber wheels gong by. I was thinking if my 87 suibaru went through this, I'd come out like leroy the corvette on the other side. :)
seems it was 2 below in the noon sun just yesterday.
Now 92F before summer solstice...two days in a row.
all that swampy cold stuff rising up from depths of frozen wasteland.
Dropped a/c by ten degrees. Must be some kinda invisible slime I washed off.
Replaced the sway bar end links things. Don't know if it'll help my problems any but the bushings are new now so I guess it can't hurt. Also dropped the transmission pan, changed the filter, and refilled transmission on buddy's F150. What a pain in the ass to do that w/o a nice fill tube/dipstick tube like we've got. Pumping the fluid in there from underneath sucks. Good thing he did all the work lol
The worst part about traveling cleaning bugs
Ryan B.
those sway bar ends are good. I don't notice sway changes.. but balljoints.
I still have to fill trans from underneath.. nv3500. :)
does not hold much, no big drama.
The worst part about traveling cleaning bugs92132095be87144f62747d2a94a36d8e.jpg60301c8a18586d982cf4aa1e534d92b0.jpg
Ryan B.
Bugs, lol
The windshield shot doesn't really show how bad it is. Bad angle it was terrible though
Water does wonders for bugs. Dripping wet rag to get the bugs wet, let 'em soak for a bit then wipe off with minimal scrubbing.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,110 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
