Spent a long time and a lot of quarters giving mine a good wash. Came out nice and then I put the tonneau back on that I took off a few months back and its covered in pollen. Oh well. Most of the truck looks good. :lol:
If you have a place to wash it get a power washer, it won't take long for it to be worth it. I get all the big stuff off with the washer and then do the rest by hand. Does a great job, and is free.
Just remembered a 100k item I forgot, spark plugs and wires. I'll probably go with Delco or Bosch.
I use delco plugs and bosch wires
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Every time I use AcDelco plugs and wires on anything they always work great. The one and only time I used Bosh plugs was in my Wife's Grand Prix and it kept fouling them.
I live in an apartment. So it's all pay wash places.
About to gas up...pray for me and my wallet
Sent from my smartass iPhone using Tapatalk
Got the lift yet?
Sent from my SGH-I927 using Tapatalk 2got a 3 inch body lift for a screaming deal. Just trying to get some help putting it on then imma do some 35 inch mud grapps. Gonna have to wait till I'm done with school before I do 37s :(
I'm anxious to see it
Will be calling on whether I can get some paint work done of my fenders and hood later today
Fixing to try a clay bar for the first time. Hope this expensive thing is as good as y'all say
Just do it right. Wash before and after with dawn soap for better results. Youve seen what it does to grease in commercials. It will take everything including wax off. So less for your clay bar to work through, and then after will clean off leftover residue.
And DONT drop it. Pretend its soap in prison.
Edited by SnakeEyes 325is
  • Like 3
Sent from my SGH-I927 using Tapatalk 2Just do it right. Wash before and after with dawn soap for better results. Youve seen what it does to grease in commercials. It will take everything including wax off. So less for your clay bar to work through, and then after will clean off leftover residue.
Thanks for the info! It must be very spongy
Mothers clay bar and meguir's caranuba wax.
Edited by zach1990
Not today but it was on Friday. I Installed my new V1 radar detector, Ended up Hard wiring it to the OnStar power feed, then took her for a 1200 mile drive to Michigan. Im really happy with the BB tune and also the new V1 that thing saved me a ton on the drive. Also did pretty good on mileage averaged around 75 mph all the way.20130719_163635_zps631d1fa0.jpg
Had a 1/4 tank left when this was taken and I had just kicked it down to "keep up with traffic"
Got my new alternator replaced with another new one (under warranty) and it fixed my flashing battery light that wouldn't go away. Got all this done at 5 am in under 20 minutes, not bad
Man do you want me to mail you my known working oem one as a "just in case"
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
