Pulled off the old, faded, scratched, and bubbled up door molding off.
Edited by Daryl Z71
Oil was changed this afternoon with Castrol GTX 10W-30 and AC Delco PF46E filter. The one I removed today was the PF61E and it was almost twice as long, so it was odd to see that this new one was also designated for the 2000MY LM7 engine.
After that I hand washed her and just went to town on all of the nooks and crannies, it suffices to say that my family thinks I'm crazy. But it just felt so right to do everything by hand at my own pace.
Ugh I know, but hopefully the little 46e serves me well.
Also forgot to mention that I used a new magnetic drain bolt since my old one was leaking. I checked this morning and there's no leakage from the filter or bolt at all for now. (Knocking on wood)
I never noticed leaking till like 3000 miles and when I took it off the rubber ring was stuck to the truck instead of filter.. it was acdelco
Edited by SarahsGMC
The rubber gasket also fell off the filter when i removed it back in January. No filter leaks that I know of though because they've all been relatively clean. All my leaks are from the damn valve covers and oil pan lol.
Gave her a wash! She's working hard up here in east Tennessee/Gatlinburg area on our family vacation! Going from our home in Florida to the mountains got her a lil durty' lol.
Thanks! We're up here on our annual family reunion. We also have a cabin that you need 4wd to get to in Maggie Valley.
I got under my pickup, pulled off the old evap canister, decided it was too freaking hot and went inside.
Would anyone like a write-up on replacing the solenoid? Commonly causes 446 and 449 I believe.
Truck is a jungle gym
Went to the nascar hauler parade leaving noticed this nice truck parked by me
Ryan
That happens all the time. Mostly when the filter is overtightened the gasket will come off and stick to the truck. Wal-Mart oil change people are infamous for having that happen then installing the new filter on top of the gasket that is stuck to the truck. Caused oil to leak and poof, blown engine in my aunts 2002 Jeep Grand Cherokee! Wal-Mart did cover the cost of the entire job and they fired their "tech" whom had signed the work order.
Funny thing is the person who signed the work order is NOT the one that doesn't know how to do an oil change, he was working the counter that day. Poor guy lost his job all because he signed a piece of paper saying the work was completed. The idiot who can't install a filter and caused the issue still works there.
Edited by BlackZ71Silverado
I'm looking at new trucks and that's what I hate about the crew cabs is the short bed. But I do tend to tote people around often so the added benefit of interior space I believe surpass the bed space
Sent while in 'Murica...
Hello? Crew cab with long bed! Best of both worlds. Haha
Sent from my LGL86C using Tapatalk
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
