Would be more fun if it was mud lol.
I picked up some power steering fluid, hopefully enough. I got some regular to flush it and then some synthetic to fill it with. Planning on doing the flush tonight, along with greasing the front end and u-joints, and cleaning and rotating wheels.
Give both the Silverado and Equinox some fresh Mobil 1. I thought since I was changing one I should do both.
Pulled the truck into the garage. About to pull the toolbox so I can fit more in the bed.
That's the only thing that keeps me from getting one.
Well you have a crew cab dont you? I normally dont pull it but I am helping my brother move. Also pulling it isnt bad. 2 nuts, slide towards tailgate about 6 inches, run 2 straps and use the tractor to pull it off.
Got my first oil change, they told me about some kind of reprogram for the odo. I told them if its not about safety stay the hell away from my computer, reading too many stories about dealer screw ups with computer programing.
Nope extended cab. That's another reason I never bought a crew cab lol
Mine will only come out maybe once a year
I'm looking at new trucks and that's what I hate about the crew cabs is the short bed. But I do tend to tote people around often so the added benefit of interior space I believe surpass the bed space
Sent while in 'Murica...
When I bought my truck it was down to this one with 46k and a white 06 SLT crew cab with with 52k. I wanted the bed space back in 2008
Plan on taking long road trips to go 4wheeling so I would have a trailer anyways. Plus I will still have this truck so if I need the bed space I can scratch up this truck haha
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
