I remember last time my 60e went out. Lost 4th at 65mph, so ran 3500 rpm for 2 miles till I got home lol
Sent from my SM-N900V using Tapatalk
I was about 15 miles from home
My transmission shit the bed tonight. Lost 4th completely, 1st sounds like there is rocks in the converter. Doesnt want to shift to second and 2nd makes noise. 3rd is the only decent gear right now
Still planning on waiting a little while before you get a new trans?
I don't like tossing money out the window but I don't think you realise the frustration that truck caused me. Let's see your truck just up and leave you stranded in the middle of know were twice before 61 000km. And then having to fight for a rental truck cause the dealer has no more curtsey vehicles left. I have a huge list of problems that truck had the 4x4 would only work when it felt like it the ignition switch would leave you stranded the oil cooler lines have to be replaced multiple times aswell as transmission cooler lines. The trucks being parked at just over basically 61 000km I'm done with it!!!!!
Letting it sit and rot wouldn't help with the frustration. At least recoup as much as you can. Or turn it into a tree house or something
Ryan
Do you mean you want the hi and low beams pluss the fog lights to all be on with the hi beams if so I remember me and a friend installed a kit from lmc truck onto his dad's 05 GMC 2500HD duramax. When done the low beams and fog lights would come on with the hi beams. Hope that answers your question.
Conky Conky, thanks no that's called the God light converstion. What I'm looking to find out is different. The head light high&low beam are in one housing and the day time and blinker are in another this converstion takes those 2 assy and uses one for all and then the trim piece off of grill comes off also. Again thanks thou.
I pick up a rebuilt unit on friday. Just a basic job. No fancy performance stuff Edited by Chris
4L60E?
4L60E?
Yes just a 4L60E. I dont have the cash for anything fancy. Got the truck lifted and dropped the driveshafts.
Someone stripped the drain bolt head
Figures that it would go out at a time where you couldn't build the trans exactly how you want it.
Driving the bigger 13 now. It's a different drive. Motor is so much quiter, brakes are better, range in the throttle is mush greater, and so much more fuel capacity.
Tuesday I picked up an aux gas tank from my storage house and took it down to a friend that could possibly get some use out of it. Cleaned the outside of the windshield and put rainx on it, changed the wiper blades too. Cleaned the drivers side of the inside and then said screw it and gave up. Torqued all 32 lug nuts to 140 ft lb or there about.
0058 Wednesday morning received a txt from my best friend's girlfriend saying her BF told her to call me since he was on duty and having a busy night. Apparently she went to world of beer and left the head lights on (on her civic, which is in MS, the lights turn on and off automatically, buddy's 4runner doesn't). Whoever she was with couldn't get it to start by jumping it. Get out there jump it and get it going. Notice the low fuel light is on and an estimated 9 miles left. Yeah that was a lie, barely made it a 1/4 mile and it died at the intersection for the gas station. Jumped it again since the battery didn't seem to strong and it had enough fuel to make the uturn at the light and into the gas station. Then followed her the 13 miles back to buddy's place. I really wish he'd learn to put gas in his vehicles, always runs them 1/4 or less of a tank and only fills up when we're going out of town. Even worse now that he just uses his patrol car since he really doesn't go many places off duty.
I love my friends...I love my friends...I lo...grrrrrr
Later today I'll be driving down to Tampa for a concert. I should probably get some sleep, at least that would be the smart thing to do right?
Edited by Chevyguy85
Getting ready to haul a '08 Lexus RX350 here. Thing blew an oil cooler line (common issue in the V6) and puked nearly every ounce of oil out on their 5 mile drive home. If their apartment was 10' further up the road, this would be a motor swap.
Found a Dorman ( :nonod: ) assembly that's all metal, instead of the little short hoses the OEM used. So, I figure it'll rust through in around the same length of time the rubber lasted. :rolleyes:
Should be a fun job. Everything is packed in there. First foray into Lexus territory. Never even sat in one before, let alone worked on one.
Time to put the Silverado to work.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
