Got mine back out of the body shop Friday, fixing my stuipdity. Then today I did a manual regen using my CTS2!!! It worked great, not that I would want to do one like that every time but I could see how it could come in helpful in some cases. :jester:
You should do a full delete with tunes.
Sent from my SM-G930V using Tapatalk
Up until recently she had a mild ticking sound exactly within the 2k rpm range but during this weekend's drive it was entirely gone. The oil was changed recently so maybe it did the trick, and something I've noticed is that driving her more does more good than harm.
After a 1,200 mile road trip in July the water pump stopped leaking, I haven't had to add any water since then!
Sent from my SM-G550T using Tapatalk
Today I swapped the 2 firefly poor excuses for back-up lights for LEDs. Will take pictures tonight.
Pretty hard to tell during the day even on a cloudy day. These have 3 LEDs pointing back through a lens and 3 pointing towards the reflector. I just did a bench test and I'll be seeing spots for an hour. You cannot look at the LED one dead on while the halogen looks like a firefly by comparison. Test was performed at 13 Volts and down 2 f stops so you could see something other than white. Couldn't take a picture headon the LED so had to take it at a slight angle.
I will post picture as soon as photobucket is back up.
Edited by Coby7
Park lights are on...
Might be too bright lol
What bulbs did you use? I have been meaning to look into this. Backing up at night is brutal with my tint plus the stock "fireflies"
I just got some cheap T10 LEDs off of ebay or some China site to see if it would be better, it is way better. If they don't last I'll get more expensive ones.
I believe these were the ones, I ordered a spare at that price. It says 30W I don't think this means 30 Watts, may mean it puts out equivalent to 30 Watts halogen bulb.
I measured a regular 921 (the ones that were in) at just under 2 Watts and the LEDs at 3 Watts. So maybe there's a missing decimal point. Or just a selling scam.
http://www.banggood.com/T10-912-921-6-LED-White-Light-30W-12V-Car-Backup-Reverse-Lamp-p-1015069.html?rmmds=search
Edited by Coby7
I have a full led swap on mine there's hundreds of different kinds I just did trial and error till I found some that work more than a week
Sent from my SM-G925V using Tapatalk
Too much Asian junk on the market.
Edited by Chevor
First time I clicked on your link it said invalid, then clicked on it just now and it's working.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
