I just did a repair on 2 Astro start FOBs for the nicest and easiest lady to talk with I ever met.
Then her friend came over with a Pro Start.
Edited by Coby7
My pinion bearing is trashed. The new set has arrived and is going in tomorrow, along with a TruTrac, axle bearings and seals, and rear brakes.
Sent from my SM-G920V using Tapatalk
Edited by kstruckcountry
  • Like 3
How easy is it to replace the outside door handles? I think i will be replacing the driver's side since it's really loose, I cant stand it.
Sent from my SM-G550T using Tapatalk
They're not too bad. Once you get the door panel off, the hardest part is trying to see and get your hands inside the door. It's pretty straightforward. Just pay attention to where all the rods or cables connect on the original, and just transfer them over.
You might just need to tighten the nuts on the handle there on the inside of the door, if one didn't bust off. That would be a nice, quick and cheap repair.
I threw a set of chrome GM handles on mine back in '07 when it was new - at the time that was the newest vehicle I had ever touched before, and didn't have a clue as to how that panel came off. Luckily there was an instruction sheet in the box that showed the 3 hidden fasteners - rest of the door just yanked off by hand. Was surprised it was that easy. Was amazed at how airtight they made the thing - actually some quality in the doors there. Miracles never cease ...
Yours should be easy to figure out - I think they still used the plastic retainers on those if I remember right - gotta be a little gentle with those, as they like to bust. I still used to reuse those things for years in my 70's and 80's cars. They'd always yank out of the cardboard panel randomly, and you'd have to wedge them back in before reassembling. Still have all the original ones on our '86 Merc..
New%20truck%20replacing%20door%20handles
I should look at my pics more closely - I just noticed the date I wrote inside the door: 8/10/08 - thought I did it when it was brand new. Guess I drove a year and a half on the ugly black stockers first.
Time - the big mind eraser! :happysad:
Edited by Jsdirt
Ran into my old truck this morning.
It's got a flat...
Wish I'd see my old truck. I'd make the guy an offer!
It had 266k miles on it when I sold it, so not likely ....
It's got a flat...
I think thats why it is parked there
I've seen my old truck once since I've sold it. I regret selling it but I didn't have the funds to repair the rust damage and it's not like it was getting any better. Invested WAY too much money into that rolling death trap to have let it go for what I did but what's done is done
Sent from my SM-N920V using Tapatalk
Enjoyed the noise free rear axle and tested out the TruTrac. I really like it. More sure-footed than the G80.
Nice - I'm gonna have to research that.
Never liked the G80 - even from day one it had quirky engagement, and always gave me the sense that it was going to grenade at any moment. Sometimes it would wait to engage after I had one wheel spinning like crazy. Not a good feeling ... or sound!
How many miles on the truck when she started howling?
I should probably be saving my pennies for a whole new driveline the way things have been looking lately, though. :uhoh:
Edited by Jsdirt
Around 140,000 when the howl started I think. About 144k now. Turns out it wasn't the pinion bearing, it was the backside carrier bearing. When the gears weren't putting pressure on it, it was able to whine I guess. Pic of the offending bearing's race.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
