Day started great, its now 1:15 and I backed into my own brick fence p
Chris
After cleaning the truck out, having a quick wash done before a slew of doctor appointments i backed into my own wrought iron brick fence pillar
damage to truck
damage to pillar
Looks like you got the pillar better than it got you at least!
that sucks,atleast it's just the plastic not the chrome
There's just some things you don't tell.
ill admit i screwed up. i park my truck on the right side of the driveway. i was trying to get it over so i put it in reverse and cut it too hard.
  • 3 weeks later...
Wow! Sorry to hear that.
I back my truck in my driveway and since our garage is set back about 20 feet from the front of the house, pulling next to the house I get within 8 - 10 inches of the wall and sometimes I wonder if I am going to hit something. So far nothing yet, thank you Lord.
haha thats not that bad, i cant tell in the picture, did it push your bumper in?
you seem to be hitting a lot of things recently
Aww that sucks. I didn't post it up but I backed into a tree while on a field trip with my son. I didn't see the tree and was backing very slow. I sat in my truck for minute and thought about how pissed I was. I got out and thank the Lord, it was the reciever hitch that hit. Nothing else. I was again thanking the Lord.
So, it happens and yours doesn't look too bad.
pfff, I backed into the wifes car last year. Her less then a month old car. I was not impressed with myself, nor the almost $1500 in damages O_o
I've made a few oopsie's in both mine and the wife's vehicles. It happens..
Tail light, backed out of side of driveway into a dead bush (previous vehicle)
Front corner marker, backed out of parking spot too sharp and into car next to me. (previous vehicle)
Passenger mirror (wife's current vehicle), impatiently waited for a truck to turn into gas station and steered around him, thought I cleared the corner of his bed...I didn't
---Trying explaining that to a wife that was deployed half way around the world while your truck is on jack stands in your drive way in the middle of a full four wheel brake job---
I've had other bad hair days but those were oopsie's that costed me $$$.
Glad it wasn't worst. I backed up into one of those tall rod iron gates (the ones that roll) backing up in my 08 Sierra and it looked like I hit a damm bear! My pass side tail lite was cracked, the bed area was all out of wack. I was sooooo pissed at myself.
I got a tow hook to the tailgate a few weeks ago... sooo angry. Still awaiting repair...
Don't feel bad, I took a small chunk out of a concrete column in our parking deck trying not to snag the stupid little Honda parked next to me, bumper took it like a champ the column not so much lol small scratch on the plastic.
Sent from my Galaxy Nexus using Tapatalk 2
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
