Stabilitrac.. Disable?????
So i have 2012 Denali. I would like to be able to have a little fun with this truck but when i get to far sideways or halfway through a doughnut stablilitrac says "NOPE" I know you can shut it off by holding down the traction control button but it still kicks in even when its off. Is there an aftermarket programmer i can get for it to let me play???
Thanks
Dont you have all wheel drive with it being a Denali so you..... so you should not get to much fun out of it anyways .
If you pull the ABS fuse it should disable it but it will also make your dash a Christmas tree.
Oh i get fun out of it. Just want more. Pulling the fuse will be a last resort. Was wondering if anyone has done an EBCM reprogram on one and just set it up as a regular sierra. The truck whips circles like nothing on pavement, but only for a circle or two before it cuts me off.
there is no button to disable it on the denali? On mine you just hold the button for 30 seconds. I believe blackbear can tune it out plus will give you more power and drivability.
I know when I hold mine down for 15 secs or so it turns everything off.. I did that once and ended up pointing the wrong direction in the street! :crackup:
on my silverado all you have to do is hold down the traction control button for about 8-10 seconds and it turns off stabilitrac.
In the manual it says it still has very limited functionality when off. 4 low totally disables it though and that's how I ran on the dunes. Dash looked like a Christmas tree with all 4 tires aired down and stabilitrack off. :lol:
