  • Replies 38
Hit up a rad shop and see what they got
Sent from my ADR6400L using Tapatalk 2
+1
The cracked plastic tank can be replaced at a radiator shop. Check with one to see what the cost to rehabilitate your current one.
Also, what's the part number for the Delphi they quoted?
There are a lot of complaints online about the Ready-Rad radiators sold at Advance.....I'm with the other guys, check w/ a local radiator shop about putting a new tank on it if there is one nearby.
Delphi part RA20043...
I think there may still be a radiator shop that hasnt gone out of business around here..Ill check tomorrow...
Yeah I wasnt sure about the Ready-Rad myself...Its the one with the lifetime warranty...
In fact that Delphi is listed on Amazon for just under 100 bucks right now...Only thing is, is that it doesnt have a drain plug..Dont know if that would be that big of a deal or not??
Lack of a drain plug is not an issue
If you tow a lot or tow heavy weight, consider a larger radiator
Yes I tow a good bit...Where would I start to find a larger one that would be a direct fit?
You can get a 34" radiator from the auto parts store. It'll cost more and I don't know if you'll have issues with the fan shroud, hoses or transmission lines lining up correctly. I'm sure someone here has done it though. I believe that's what came in the 2500 series....
I've towed a mustang on a car trailer w/ my truck (same radiator as yours) and it ran normal temperature. I wouldn't worry about it unless you're pushing the limits of your truck.
Ill do some research..I posted about wanting to install one on here some years ago and from what I remember there was mixed opinions and tons of which ones to stay away from and ones that were a pain because you had to cut this that and the other and so on..Needless to say I decided not to try and fool with it after that thread...I do tow a large bass boat and have always thought one would be a good extra measure...For some reason my truck has always ran a little above normal in the temp department..IIf I sit in a drive thru the tem will shoot up to 235 on no time..Its always been this way since new...And I have always flushed the system very well every couple of years..
If you are going to replace the radiator, check out "Be Cool" they are all aluminum, double to triple core, no plastic.
http://becool.com/
