New updated GM picture
  • Replies 42
It's definitely a projector but to my eyes the color temperature is wrong to be HID.
Time will tell. I bet the front end is gorgeous. The rest scares me. I'm not going to jump the gun and "jump ship" yet until I can see one in person.
Sent from the Blackberry Bold 9900 using Tapatalk
I absolutely hated the gmt900's for the 1st yr or 2 then they grew on me, hence I own a 2012 :lol:
Ryan
Ryan
This. I remember when everyone hated and bashed the GMT900 looks, and after a little while everyone seemed to like it.
The doors look odd
Ryan
Probably to help reduce the amount of snow that falls into the cab when you open the doors in the winter.
Well I just hope and holding on for the grand unveil. Hopefully we will all be pleasantly surprised.
Anyone know when the SUVs will be updated? Wonder what they will do and improve for the Escalade?
Truck trend has a shot of a Yukon XL or a burb don't remember.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
I absolutely hated the gmt900's for the 1st yr or 2 then they grew on me, hence I own a 2012 :lol: Ryan
I didn't "hate" the 900's when they came out, but was VERY disappointed! I thought the 900 suv's & avy looked great. And thought the truck should have had the same front end as well!
Chris
It is probably just me but the front reminds me of a Ford, the cab of Dodge and the rear of Chevy. :lol:
I agree, but the tailgate has a spoiler look like a Dodge as well. That cab is so Dodge its crazy.
Did anybody else notice the center sliding split rear window? Finally.
That feature is on this generation of trucks too...
I have no use for sliding rear windows myself but to everyone who has commented about the one in these pics being small, I agree but I think that is intentional- the "cutout" for the slider seems crude. That has to be a false panel of some sort.
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
