3.08 vs 3.43
Hello everyone,
I am shopping around for a 2013 4x4 Sierra with the 5.3 and was wondering what would be better for my situation. I drive 85% in the city, 15% highway and never pull any kind of trailer or boat. I will keep the same tire size and will not lift the truck. I live is south Lousiana and all roads are flat. I need the 4x4 for the dirt roads during hunting season.
So far the only trucks that I have found have the 3.08. Since I dont pull anything and the roads are flat, would this be ok? And would the 3.08 give me better mileage? Do they offer the 4x4 in the 4.8?
thanks guys
  • Replies 45
You can get a 4x4 4.8. he 3.08 will offer better hwy MPG's. Also you double posted so I am going to take care of that other thread
I would go 3.73 if possible. I have 3.73 in my 2006 and it still makes 18 mpg at 70. I don't know what the difference in mpg is exactly in town, but everyone says lower gears do better in town.
I have the 3.08 and I can't prove anything about getting better mpgs compared to a friends 3.42. If anything 3.42 might help with low-end acceleration from a stop...such as city driving. I just think the first gear isn't quite low enough sometimes. Really gotta feather the throttle from a stop.
3.73 is no longer a widely available option like it was for the GMT-800's
I would go with 3.43 cant imagine would really make a big difference in mpg. also 3.43 has more towing capacity which might be something you need down the road or if you ever want to sell it the prospective buyer may want to tow with it.
3.43??? GM doesnt have a 3.43 rear end. Its 3.42 :)
4.10
Sent from my Nokia 5190 using Tapatalk 2
Sure if you add aftermarket gears
The only reason to buy a 3.08 would be if your situation was reversed - 85% highway, 15% town - OR you can't find anything else... If you find a 3.42, go with that ratio as first choice.
I have a 2011Yukon XL with 3.08 's and a 6 speed transmission. Its plenty quick off the line and idles down the highway. Highway mileage 20.5-21 , city 16-17.
My 08 has a 3.73 rear end, the 13 Z71 I am test driving has a 3.42. The only thing I have noticed, is at 70 my 08 turns 2100 RPM and this 13 turns about 1700 RPM. Since the RPM's are so much lower, it seems to spend less time in V4 mode.
Around here, the Z71's mostly have 3.42 gears and the 2wd's have the 3.08's for the most part.
But to answer your question, if you do not pull trailers and are not putting larger tires on it, the 3.08 gears would be fine.
As stated above, the 3.42 would be better for you since you drive moslty city. The mileage difference isnt gonna be that much different between the two on the highway. but, in the city, it could be a difference of up to 2mpg depending on how heavy your foot is. Plus, you would have the lower gears for offroad and when you tow. My wifes Tahoe has 3.42s and I would not have it with any higher gears.
IMO, go with the Z71 with the 3.42s.
The cheapest deal you can get and regear it to 4.10....... or even 3.73 and then you technically could get the dealership to reflash the TCM for it as it a factory available ratio with the 6L80E in the NHT package. Not sure on 4.10 as it is available factory but only on the 6L90E equipped 2500/3500 models thus the dealer probably can't add it to your VIN...... but you could always ask. 3.73 with a 5.3/6L80E has been done by guys at the dealer.....
Best mod you could ever do for drivablity either way. I have driven a Yukon with a 5.3 and 6L80E and it was a turd that was hard pressed to do much of anything..... I couldn't imagine putting up for longer than I had too.
It's not a race car lol I got a regular cab with 3.23 4.8 and I compared them with many trucks at work and the only noticeable change is when you have a bigger motor. One tons to half tons 4.3l to 6.2l we got em all. 6.0l flat deck duellys haul ass lol
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
