2007 Yukon Denali XL Mafia Photoshoot
Rayaz_XL
Wanted to do a photoshoot of my 07' Yukon Denali XL in an area with older run down buildings with a " mafia shootout" kind of look.
Looks great but I wouldn't leave that hitch in if I wasn't towing at the time. Just an opinion.
Sent from my Nokia 5190 using Tapatalk 2
Leave the hitch if you don't want rear end damage from retards.
Pics are great Denali looks immaculate good work
Sent from your truck via Tapatalk
Looks really sharp and I'll second the leaving the hitch in. Saved my rear a few times now. Also I keep my locked in so it wouldn't be too easy to steal.
Thanks alot for the compliments guys, and the hitch is there exactly for the idiots although I could have took it off and installed the cover panel for the pictures
That is the biggest crock going. All you are doing is letting the hitch rust up good and solid in there I've seen it a dozen times then if you need to change the hitch for whatever reason you need a torch.
Yeah it will stop damage:rolleyes:
Just ask this guy
http://www.gm-trucks.com/forums/index.php?showtopic=135504
3 people have rear ended my truck. 3 times that hitch stopped them every time. It's not rusted and it's pulled out and lubed every month. Take care of your equipment and it will serve you well.
I only pull mine out when I put it in the garage. My new garage is 3 ft longer and 5 ft wider than the traditional 2 car garage. Plus the door opening is 10 ft high
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
This can apply to many things in life.
"it's pulled out and lubed every month. Take care of your equipment and it will serve you well."
You guys are killin' me. Throw in the tow strap conversation and you'll know why my gutter company's slogan was "Our Minds Are In Your Gutter"
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
    • It was all part of the tiny bit of fuel savings it goes towards what was mandated by the government. Much like cylinder deactivation. That was relaxed by the recent administration. All that doesn’t help the individual buyer. But as a whole helps the manufacturer to try to reach the previous ridiculous past mileage per gallon mandate. So yes it was mandated and added cost to the vehicle.
    • You do realize that auto stop/start...was never mandated by the fed...right?     EPA Says It's 'Killing' Stop-Start, and Here's What Automakers Have to Say   "Start‑stop technology has never been federally mandated, and the EPA’s recent action removes regulatory incentives associated with it rather than prohibiting its use."
    • Anytime the government mandates something, you can bet on it being absolutely senseless.
    • just logged my best MPG for one leg this am - drove home from the Denver Airport, 45 min drive - all freeway, lots of traffic so speeds were limited and some stop and go, got 17.7 for the ~30 mile trip.
