Rear Brake Replacments
Looking for the thoughts of fellow owners, I Have a 2004 Sierra 1500 SLE replacing the rear brake Pads & Rotors the question is how do you guys feel about the performance brake kits available EBC, Brembo,PowerStop or Good Ole OEM AC Delco Rotors and pads, If you have changed to what did you change and is there a difference in wear and maintaince ? Thanks in advance for all thoughts shared
I went with the "Baer" eradaspeed rotors and "Hawk" HPS pads.
While you are doing the change, think about replacing your stock brake hoses with a pair of "Russell" SS braided hose. They make a complete kit with SS banjo fittings and washers.
Unless you're planning on road racing the thing or you like to tailgate other drivers constantly I'd stick w/ the stock type equipment.
EBC are supposed to be really good, I'm going with their Greenstuff on my 2006. Greenstuff are supposed to deal with the elements better.
I went with Brembo rotors and EBC yellows all around on my Suburban. Made a big difference in stopping power. The yellows do leave a lot of brake dust on the wheels, but, for me, it's a small price to pay.
About a year ago, I went with EBC slotted and dimpled rotors with Greenstuff pads. The rotors are terrible. The EBC site didn't tell you that a constant metal to metal rubbing noise is normal with the rotors. When I called their customer service department they offered to replace the slotted and dimpled rotors with the standard high quality replacement EBC rotors and Yellowstuff pads FOR FREE, which I ended up doing and works well. It looks like they've revised the design on the slotted rotors so maybe noise isn't an issue anymore. Although the slotted and dimpled rotors made noise and were annoying, I can't complain about their customer service.
Edit: I just realized this was a thread for rear pads and rotors. Obviously with an '08 I've got drums so my experience with EBC was on the front. Sorry for confusion...
Since you have a rear disc 2004 GM truck, don't skimp out on the rear pads. AC Delco ceramic would be great, EBC, etc even better. Don't forget to check your e-brake linings at this time too.
The 1999 (NBS)-2004 GM 1/2 tons really use the rear brakes more than we think.
Goodluck....
  • 3 weeks later...
You aren't kidding about using the rear pads. I replaced my rears with Carquest Blue ceramics. No dice. Braking performance noticeably worse. I had to convince my self that the pads were the issue, couldn't believe the rear pads would make such a difference. Went back to OEM ACDelcos (not Durastops). Braking returned immediately and was perfect. Go with OEM pads for the rear.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
