Edmunds 2014 GMC Sierra 1500 Review
  • Replies 30
"The off-road/all-weather-focused All-Terrain model, which features Rancho shocks, hill descent control and an automatic locking rear differential, will join the lineup later in the year."
Later in the year?
It is an old article with a new date on it. Harsh comment. Ouch!
Most Recommended Comments
By nukedetroit
on 06/12/13
7:40 AM PST
These supposedly "new" trucks have been met with a collective yawn by other publications, and - most importantly - potential customers. As this was a manufacturer event, I can only assume that GM's press drones were looking over your shoulder as you wrote this discordantly fawning piece of... journalism.
It is a new article released 6/12/13.
The older different article is here http://www.edmunds.com/gmc/sierra-1500/2014/
Yes, harsh comment.
  • 1 month later...
2014 GMC Sierra 1500 - Drive Time Review with Steve Hammes
Didnt want to start another review thread so I will just add to this one...
interesting comments about the ride quality being worse than 2013. I had a hard time believing that. So to the new 2014 owners ( that had previous 2007-2013) what is your take ? is ride better or worse?
The ride did not look that harsh to me. I was wondering if the wheels/tires would make a difference that could be perceived as a harsh ride - bigger wheels usually means less rubber means the tire absorbs less of the road bumps.
5:40 "The rear seat vents blow hot air, a major complaint of his rear passengers"
Looks like he encountered the same thing I did. GM has to fix this flaw.
you have to get past this...please...it is best for your long term health to do so...the major flaw is the lack of cooling/heating air vents for the rear of the cab...My dealer said they and others at the GM mtgs/rep contacts had been asking for such.
Hot front seats should not vent on rear passengers. That's just dumb. Especially on a crew cab or extended cab where rear passengers are the norm.
Sent using Tapatalk
it was a decent review but you can tell that the journalist is a strict car guy. We need real truck men to review these machines.
And am I the only one who finds it ironic that the front bumper only has a few inches of ground clearance on a 4x4? If you did anything remotely offroad it would tear off in a jiff. My truck is pretty low too, maybe even lower, but it's not for "off roading".
The front air dam does seem to be awfully low, low enough that some city curbs are going to be a problem too. I'm not used to having to worry about curbs in a pickup truck. You can of course remove the air dam but there are a lot of bolts that need to be removed and there's going to a cost in fuel efficiency and perhaps cooling.
The Z71 package is going to make for a rougher ride - I wonder if that was what the reviewer experienced? If I could get skid plate protection separate from the Z71 package, I would forgo that package altogether.
Drove a SLT short bed with the 20" wheels and the Z71 package yesterday. I thought it rode pretty good. I purposely crossed railroad tracks, any rough spots I saw. Did seem a little solid on one small pothole. Thats the short sidewall tires I would think. Over all I was impressed. If it would have been the right color it would probably be headed for my garage. While I'm here anyone have the Bose speakers?
Tons of people removed the air dam from their 900-series trucks, myself included and never have had cooling issues or serious drops in fuel efficiency.
IMHO, the "Bose" package does nothing for trucks with the 40/20/40 seats. There's not much base response and I couldn't tell a huge difference between the standard audio system. If you have the full console the package includes a subwoofer and I have much better bass response. It's not going to blow you away but it's passable and the new cab sealing makes for a better experience than past Bose systems.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
