I'd give Fabtech a call and see what the difference is between the K1068 kit and the GEN II K1084. Also, check out the prices on this website too they have the GEN II kit for 30% off plus no sales tax and free shipping. Also, when you speak with Fabtech get an estimate install time, they're install instructions do not state one.
Gen 2 doesn't sit as high and doesn't increase track width at all.
Sent from my E6853 using Tapatalk
So GEN II isn't a replacement for the first set of lift kits that they released?
Hmm, I'm thinking Fabtech isn't the way to go. Here is the difference. I also don't like what that note at the very bottom of the "1068" kit tell you. That CV shaft is $1000 if you need it. It doesn't say that on the other kits. I'm kinda confused now.
GEN II System
"This new Gen II system retains the factory track width keeping the tires under the fenders for a clean appearance. With the factory track width retained the front Sway Bar utilizes the stock end links and mounting holes keeping the leverage on the bar proper. There are no CV spacers, impact struts or add a leafs required for installation. The front differential is relocated in a manner so that when driving at higher 4 wheel drive speeds vibration is reduced.
The GEN II Basic System utilizes a simplistic upper Coilover spacer that provides lift from the top of the shock rather than bottom up with reduced install time. Rear shocks are Performance Twin Tubes.
All bracketry and the skid plate is constructed of 1/4” thick steel for maximum strength and proven reliability.
This 6” system will level the stance of the vehicle compared to the factory nose down rake. For those customers that want a factory nose down appearance order optional add a leaf, Part # FTS212
The system passes FMVSS 126 standards for stability control functionality as tested by an independent lab.
NOTE- Before ordering visually check your vehicle’s factory suspension for aluminum or steel version. This system will only fit factory aluminum suspension vehicles.
This system qualifies for our 5/60 Powertrain Warranty. To find out more CLICK HERE
Kit# K1084
  • Use 35/1250R17 tires w/ 17x8 wheels w/ 5” BS w/ minor trimming
  • Use 325/65R18 tires w/ 18x9 wheels w/ 5” BS w/ minor trimming
  • Use 35/1250R20 tires w/ 20x9 wheels w/ 5” BS w/ minor trimming
Oty Part # Description 1 FTS21170 Component Box 1 GEN II 1 FTS21171 Coilover Spacer Kit 1 FTS21172 Component Box 2 GEN II - Aluminum 2 FTS7240 Rear Performance Shock
*FOOTNOTES
1. Will not fit models with Factory AutoRide shocks.
8. Will not fit all wheel drive models.
14. Cannot use OEM wheel and tire.
17. Does not fit standard cab.
127. Fits 2014 models with Factory aluminum suspension only."
and
1068 SYSTEM
"Our 6” Basic System for the factory Aluminum suspension has been designed utilizing our industry leading crossmember and spindle technology.
Lift is accomplished by utilizing the factory front Coilover shocks with steel spacers that helps retain the stock ride of the front suspension. The 1/4” thick steel lower control arm has been formed to fit to the bottom of the 2014 frame without having to cut or modify it for a fast installation. Extensive design work was given to the extended length steering knuckles specifically for the Aluminum component version keeping track width near stock and working properly with the Stablitrac® safety functions.
The front differential is relocated with heavy duty brackets while a tightly formed 1/4 ” thick steel skid plate provides protection for offroad use. The rear suspension is upgraded with add a leafs and 5” tall blocks and u bolts. The stock rear shocks are replaced with Performance shocks for increase dampening.
- Front lower control arm Crossmember forms to bottom of frame without cutting
- Offset ductile Steering Knuckles keep tires under fenders
- Includes Crossmember cross tubes to distribute front suspension impact loads
- No disassembly of factory coilover assembly required for installation
- Systems compatible with factory Stablitrac®
Kit# K1068
Oty Part # Description 1 FTS21137 Component Box 1 1 FTS21138 Coilover Spacer Kit 1 FTS21139 Component Box 2 - Aluminum 2 FTS7240 Rear Performance Shock
*FOOTNOTES
136. Some vehicles may experience front driveline vibration in 4WD. Order FTS21192 CV Driveshaft Kit if occurs."
How is the comparison in ride between the GMC and the RAM?
I think the ride is better in the ram. Most likely due to the coil springs in the rear as opposed to leaf springs. However, the seats and overall quality are better in the Sierra. I always feel composed and secure when in my Sierra. I didn't always have that feeling in the ram.
I don't regret getting rid of the ram, and I don't regret getting this Sierra at all.
Josh
It almost seems better to get the Zone 6.5" lift... I can get that installed for $800.00 It would be cheaper than the Fabtech. The BDS is $2014 + $800.00 install. It's about $1000 more.
I think both the Zone and Fabtech are good options. There's several guys on this forum who have the Fabtech lifts and haven't had any issues. Also if the lift isn't impacting the factory track width then I wouldn't worry about CV's. Needless to say picking a lift kit is freaking difficult when you starting looking at all the details lol.
Anyone have pics of the width of the stock wheels on a BDS? I know it will widen the track but i just want to see how much. Preferably the silverado 20s.
Sent from my Note 4 on Tapashit
Zone is made by BDS from what i have heard? I've never owned a lifted truck, just leveling kits on the last 4 of them. It's very difficult.
Edited by Swankster988
Also, that 1068 kit by Fabtech must be doing something if they had to put a note about vibration issues with that system, the fix they have is a different CV for $1000 which kind of tells me to avoid that kit because there is a known issue. It seems they then designed the GEN II kit which doesn't have that issue and doesn't change the factory track width.
Yes Zone is owned by Sport Truck USA who also owns BDS and JKS. Basically Zone is BDS' little brother designed to compete with guys like Ready Lift and Rough Country.
Sent from my SM-G900P using Tapatalk
What made you decide to choose the BDS kit over the Zone or any of the other choices you had to choose from?
I went with the BDS because of their superior build quality, reputation, warranties (no fine print and 60k mile) and coilovers. Zero regrets, it has been a fantastic kit. Also here are the pictures you wanted too. Again my wheel specs are 20x10 (-24 offset/4.5"bs) and 35x13.5R20 Toyo RT's.
I went with the BDS because of their superior build quality, reputation, warranties (no fine print and 60k mile) and coilovers. Zero regrets, it has been a fantastic kit. Also here are the pictures you wanted too. Again my wheel specs are 20x10 (-24 offset/4.5"bs) and 35x13.5R20 Toyo RT's.de1d77f60700f5f9d3d79488f95e4db8.jpg3f65cbc37e35383fabde63166d17a964.jpgabd0beb411a5eed1f09ca0bd06922441.jpg
ok so these pics are a BDS 4" kit? Edited by Csjumper2003
That is the exact look I am going for. So you picked the BDS kit with coil overs correct?
No 6" but the parking lot at my apartment complex slopes down. Thats why the front looks low.
I am the BDS kit with Fox coil overs, fox 2.0 shocks for the rear and the BDS glide ride leaf springs.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 522 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
