ive heard that from quite a few people. i don't get why mine will do it. another guy i talked to at work has a Black A/T w/6.2 and he said his will go into v4 at high speeds also.
side note: i really wish i coul have a v4 override of some sort, so i could force it into v4 when i want
Mine will go into V4 at 80 mph on a flat road in cruise.
Here's my mileage for the year. Calculated at every fillup. No cherry picking 5 mile down hill coasting. :drool:
With the exception of the initial tank of 87 and two tanks of 87 when I had to fillup with out corn juice nearby, every tank has been E85.
(google drive link...)
https://docs.google.com/spreadsheets/d/1hMS7q555NoW6MTXWyWI9ckqCsP0PD6sHvBrrCdbQZpc/edit?usp=sharing
Edited by bigsapper
At the dealer where I bought my truck, I test drove both my truck and my truck's twin with the 3:42 just for comparison and I can say that to me, from 0-70, if there was any difference at all, it was so slight that I only thought I might have noticed something, but since I couldn't see any real difference and only rarely pull a trailer, I went with the 3:08 for the better MPGs - and yes, it pulls great after - and before 65 IMO.
The performance of these trucks is really exceptional IMO.
I test drove a 3.42 and wasn't really impressed when compared to my Denali...the 3.73 behaves much better. The loaner 3.08 seemed to pull better than my 3.73 above 70. Probably in my head.
In the cold weather (below -15 celcius) does anyone notice a dramatic drop in MPG?
In Louisiana we are only down to the 30-40s during the day and I have noticed a drastic drop. Can usually average around 18 mpg per tank of i take interstate most of the tank but lately I have been getting 12-14 per tank.
Yes, mine drops when the temps get under 35 or so and it drops quick. LIke from 18ish to 15. Has done this ever since GM did the catching on fire recall. From what I understand to solve the problem they richened the mixture to keep the exhaust cooler. Evidently running really lean was the main cause of the fires as the exhaust manifolds would get so hot while idling plastic that was near by would melt and then catch on fire when it finally dripped on the exhaust.
Yes -15 Fahrenheit or colder I get around 11-13 mpg. The wind was blowing terribly also. About 30-45 mph so wind was also a problem.
I have had my RCSB 5.3 since June and have (figuring roughly) filled the tank 6 times for a total of 2300 miles and I'm averaging 16mpg and only have to drive 1 mile to work with no red lights. The truck really never gets warmed up good before I get to work. I will really start keeping my eye on it on the next fill up with the Range AFM disabler with some interstate driving and BTW the traffic will roll at 80MPH and up.
RT
I have a reg cab sb with 3.42s and 5.3 and its getting 17.3 mpg. Feel like I should be getting more. Driving is 75mph on hgwy and I do about 70 percent of driving in city
I bet it's peppy with the 3.42's. Since I don't do much hwy running I have considered 3.73's in mine.
Yeah its not the fastest but I came from an 09 manual gt and I still feel like this is a bit quicker. Really want to go to 3.73s or 4.10s but want to find a setup that isn't whiny/noisy. Y'all know of any?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
