I will be posting a plug left over from my second set in the for sale forum. I purchased 2 set and don't need the second plug. It has a couple feet of wire so you can wire up some custom lights and utilize the switch inside the cab.
Just as a heads up:
The junction box comes with a cover for the plug that these plug into. So I made my own plug out of the cover with a couple parts from other plugs i had laying around and sealed it with silicone. It works perfect and actually is weatherproof since the cover has all the gaskets and such installed.
Not the prettiest thing but it works just fine.
I drilled our the two holes that i needed to use for the wires. Note that the black is the ground terminal and the blue is the positive. These are the only two used for the plug.
Hope this helps anyone who wants to do this without having the factory plug in hand.
  • Like 4
I just picked up some GM bed lighting (23145347) - one set to put in back of my pickup. I was surprise the lights are all plastic which I thought it would be some metal to it. They were made in Mexico. No instruction came in the package so I am glad there are directions in this topic. I am not going crazy and just put them in the proper way. I picked up my through Shopchevyparts.com for $106.83 (total) shipped to the door. A lot better than the dealer at $135 plus CT tax $143.57 = $36.74 savings.
I installed my bed lights on Friday and checked them out in the dark garage. It appears to be enough lighting with the cargo light and two under the bed lighting. I don't see a need to add any more lights to the bed.
SPST w/ Diode vs SPDT "3-way" switch wiring methods.
*Note: called out a 5 amp diode, but bed lights are so low draw, you could use a 2 or 3 amp diode.
Thanks for this. Going to be installing a 3 way switch in my bed so I can turn them on without going to the cab.
At least my second set ordered today off ebay. Prices are solid at 99 bucks shipped now.
If you have a tonneau cover, the extra two in the foward part of the bed really enhance the lighting. If you do not have a tonneau, then the two in the back are more than sufficient along with the cargo lamp on the back of the cab.
My kit is going in today! (factory kit). I may add two more up in front of the bed as Prdtrgttr did if I want more light once the first set is in.
The second set helps a lot! Especially if you have a tonneau.
I have the Fold-A-Cover tonneau. I suspect once I get the first two in, I'll want two more...
Edited by Nickshu
Ooops, double post.
Edited by Nickshu
Alright, fellas, I've hit a road block, and I need some help. I've got a 2014 Chevy Silverado 2 wd, very basic truck. I've got a camper shell on it, made by the fine folks over at LEER, and that's where I keep the dogs when the family travels. We often end up traveling at night, so I want some sort of light inside the camper shell, that I can turn on from inside the cab as we're traveling, glance in the rearview to check on the dogs, and turn it off again so I can see out the back window.
The logical thing is to plug the lights into the rear bus, in the same 'up' socket where these under-rail LEDs would plug in. So, this should be simple, right? :banghead: Not so much. After hours and hours of research, I've come up with the following. According to a GMUpfitter.com bulletin, the part number for the plug that I need is GM 13581768. They also go on to say it cross references with Tyco Electronics part number 2109441-2. But, herein lies the rub... I have yet to find anywhere that I can buy less than 1,000 of them. At $5 each, that would be a steal... except that I only need ONE.
Anybody got any ideas? I'd be forever in your debt.
Oh, yeah, the belletin is at the link, if anyone wants to see it. Shows the pin-outs for all of the connections in the X63 junction box, which might come in handy. http://gmupfitter.com/files/media/photo/510/UI%20Bulletin_113.pdf
You do know that the bed rail lights can only be turned on when the vehicle is in neutral or in park, while driving the lights cannot be activated.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!
:smoker::M16: I don't know HOW many hours of research I've done... and never came across that little nugget of information. Well, at least you saved me a few $$'s and a couple hours of installation. Boy, would I have been mad. Thanks. Back to the drawing board.
Yea I don't think anyone really mentions that info other than people who try to use the switch while driving!
Also, just a suggestion, if I were you, I would put in a small dimmable light under the rail on either side, that way the dogs have a constant light to see easily, and then attatch a slightly stronger overhead light that could be turned on and off from the cab.
Also you don't have the center console do you? If you do, then I have a great spot to hide a switch for the lights!
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
