After having issues of getting the correct oem kit for my 2015 I opted to go with the kit from Xkglow. I wanted to make sure I could turn it on and off in the rear of the truck and it also has a auto timer that well shut it off.
05eb11f7b6f49f8267b628326c7b103f.jpgc3cde2dc5677dbb06eea9f0ab7ab8502.jpgdaab89ad00c41718e78e13b3dba33bce.jpg
Sent from my SM-G920V using Tapatalk
  • Like 4
Hey that is sweet! Where did you pick up the power source? I want to do the same thing for my Silverado.
yes it does
Does this harness work for a 2014 Silverado 1500? when I typed the part number in on a GM parts store it indicated that it fits the 2500's but not the 1500s
Does anyone have any suggestions on how to convert the cover into the harness connector? I got a set on eBay (part # 23295942) that was supposed to fit '14 - '16s but when I went to install them today I realized the plug is a 6 pin and not 8 pin as it should be. Because I purchased them 6 weeks ago eBay cant help me and the seller is no longer a registered eBay user (shocking). I can drill out the back to get the wires through but I'm not sure how to get them out of the one harness and into the correct pins on the cover without destroying them. Any advice would be greatly appreciated.
Hey I can't remember if I had asked or not but, would you want to sell the harness? I have a '16 and could use it. Shoot me a PM if you want to.
Thanks,
Aaron.
Trailer plug has constant 12V, just T-Tap at the rear of the harness.
Edited by TheTunaHunter
Hi all, brand new here and still catching up on the wealth of knowledge.
One question I have is...has anyone ran aftermarket under rail lights to the switch for a roof mounted light? I have a 2013 Z71 with a roof light switch but I can't imagine a situation where I would ever need a roof light, but I really want to put in under rails.
So you have the pre-wired beacon package. It's do-able, you just need to locate the beacon harness, should be accessible vial overhead console, and connect to it. Run your wires down the pillar and out to the rear of the truck. If you used a relay you could control the lights from the switch for the roof mounted light, as well as from a second switch near the bed.
Not having the overhead light inside come on when I try to check on cargo while in the driver's seat would be good, being able to turn them on from the rear would certainly be even better! Gonna have to poke around and find that harness. Thanks
Installed mine today, bought this kit:
http://www.amazon.com/Large-Truck-Lighting-Toyota-Nissan/dp/B00R11TCR8/ref=sr_1_1?s=automotive&ie=UTF8&qid=1457317498&sr=1-1&keywords=Large+Truck+Bed+Lighting+Light+Kit+32+WHITE+LED+for+Chevy+Ford+Toyota+Nissan+Dodge
Drilled out the connector cover and used some spades to hook the whole thing up! Works off the interior switch now. Much more light than the OEM kit that had come on my Sierra.
How did you mount these lights?
I'm in the process of doing something like this but I don't know how I want to mount them but I want to hide the lights.
Any suggestions?
I will be using the factory harness to connect this to the cargo lights
Any suggestions?
They have self adhesive backing, I stuck 'em under the bed tops.
What effect will the summer heat have on the adhesive? We tend to get triple digits during the summer, out here.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
