I've seen one with 35's. Problem is, they don't give very good specs as far as if trimming was required and what wheel offsets are on the truck. I'll dig up the picture of it.
Here's the one I saw. But, don't know any specs on it unfortunately.
Edited by SB09
This is my plan.. offset may set me back thou...
2" level (2.5 inch actually only lifts about 1.5" from what i read) Stock 20's with a 305 55 R20. Right now it has 275 55 r20
I may have to use wheel spacers to move it outward away from the sway bar
You'd be the first I've seen post specs what it takes to accomplish this. So, if you do it, please help us timid ones out :help: so we know we've got it right the first time.
I believe the stock Rims are 18+ offset... I want the so cal look (Front little taller then the back) I am thinking the 1.5" wheel spacers will be needed. I will try without first
Trying to source a 3.5 inch level
I know they have them for my 07 so they are out there
Edited by Evanski9
2" Rough Country Leveling Kit.... 275/65/20 BF Goodrich AT-KO..... slight scrub on the inner fender liner at full turn....
2.5" leveling kit
275/65/20 is what I have, 34.2" tall, the 35s rubbed too much
I went with a 2" level because I had heard some stories/rumors that a 2.5" can mess something up with electrical or something along those lines. How true it is - I do not know. The 2" looks level to me, getting some new tires put on today, I'll post some new pics later today. Sent from my iPhone using Tapatalk
Where did you hear about this?
Have the 2.5" on mine now for two months and have had no problems at all.
That's good to know. Maybe I'll keep an eye on things and go up that .5". Although I don't know if it will really make that big of a difference. Keep us updated - like I said it was most likely stories/rumor, but not something I wanted to risk. Sent from my iPhone using Tapatalk
I have had my 2.5 for just under 6 months and have put over 10,000 miles on it in that time. No problems what so ever.
All done with tires. 275/70/18 Nitto Terra Grapplers. (Window tint later today) y7erudyz.jpg (Stock): natypasa.jpg (2" Leveling Kit): 9yjy8u6e.jpg Sent from my iPhone using Tapatalk
what kind of wheels are those. if you don't want to post here can you send me a PM plz. those wheels and tires made your truck look 100x better!
All done with tires. 275/70/18 Nitto Terra Grapplers. (Window tint later today) (Stock): (2" Leveling Kit): Sent from my iPhone using Tapatalk
Nitto Terra Grapplers. 275/70/18
I am actually going to call the tire place tomorrow and see if they will take them back and order me the same tires but for a 20" wheel. Think it might look a little better - I they will do it. Doubtful.
Nitto Terra Grapplers. 275/70/18 I am actually going to call the tire place tomorrow and see if they will take them back and order me the same tires but for a 20" wheel. Think it might look a little better - I they will do it. Doubtful. Sent from my iPhone using Tapatalk
no not the tires I know the tires are nittos. what kind of wheels are those?
CCM 3" leveling kit, i bought it off of ebay $80.00. i also have air bags in the rear. i tow a 18' trailer.
I just got a 2in BDS Leveling kit installed at dealer. That is what they recommend because I tow trailers with my truck. Looks great and level. The ride of the truck has changed. It is a lot stiffer almost like a 2500 HD. I also upgraded rims from 18s to 20s.May have a bit to do with ride?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 384 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
