Keep in mind it's not just rolling resistance to consider when fuel economy is a concern. Taller tires take more power to turn to accelerate the truck at the same rate. They also take more power to keep the truck moving thru the wind resistance at freeway speeds.
A set of icons will be my next upgrade. I would've done them this time but I ran out if money ha
Lol gotcha. I wanna do fox 2.5's on my new high country
Sent from Tapashit
What size tires are you running on your truck? Any rubbing?
305/65/18 and yeah they rub in reverse a bit... More trimming to come though
A bit off topic, but has anyone put on Bilstein 5100's on their truck yet? I have a 14 GMC AT, with the RC 2.5 and I ordered the 3" blocks for the rear. I pulled a trailer last week and didn't like the sag. I have the airbags I removed from my 12 F150 KR, just don't want to install them myself. It was bad enough taking them off. Plus I would like a bit more height. I'm 6'4", and installed my Amp steps and I keep forgetting they are there. My F150 had a 4" Rancho lift. Just thought I would ask I have been told they are not out yet.
TRagan
TRagan
So I ordered the ready lift 2.5 kit with the 3" block for the back. Just curious what's the max size I can go without rubbing and does anyone have pics of this setup?
Edited by Nemo39
Well the readylift 2.25 front level kit is installed, and a 3" block on the back...Like the rake plus I tow a boat, sled and quad so needed it for sag. Anywho looking at beefing up the tires a little. Looking at nitto terra grapplers or cooper zeon ltz. Looking at 305 50 20...Thinking they should work by size calculator but any experience would help if you would like to chime in!
You should be good to go with that size on stock wheels. I'm running a 295/40r24 which measures to a 33.3 with 2.5" level.
I'd like to see some pics......that's the same Kit I'm going to install once my truck gets here.
I received a lower arm spacer kit today. Machined aluminum spacers nicely made. The instructions didn't indicate how much each of the spacers lift the truck.
The kit came with 6 blocks total, 2 each of 1/2", 3/4" and 1 1/8" thickness. Question for those of you that have done this: Does the block lift the truck twice the thickness of the block (1/2" = 1", 3/4" = 1 1/2", etc.) ?
It is roughly a ratio of 1:2. 1" spacer will raise the front approx 2". I put on the 1/4" and the 1/2" (.75 total) and raised it 1.5 inches.
ReadyLift 2.25 Level on stock 22's
Fender height before F/37in R/39in
Side view
Fender height after F/39in R/39in
2.25 Level
    Dom Colussi
    Dom Colussi
  • Who's Online   2 Members, 0 Anonymous, 483 Guests (See full list)
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
