That's what I thought, just wanted to be sure because I'll be ordering a set soon and I cant decide which one I should get. I know the size will be 275/65/20 but still undecided Toyo Open Country AT or MT. I might go with the MT for the more aggressive look.
Also realize that there is Open Country AT and Open Country AT2. I have the AT on my truck. The AT is an older model and some places still carry them. The sidewall is less aggressive looking on the AT than the AT2. Just be aware.
I'll keep that in mind thanks.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
20", 35 toyo mt
Looks good!
What lift are you running? Those are stock wheels right?
Installed a readylift leveling kit about 2 weeks ago. Went to re-check all bolts and noticed a couple things that I wanted to check with everyone here. 2014 Crew Cab LTZ Z71 4wd. Installed 2.25" Readylift up front and their +1 in the rear. Noticed that the "washer" looking pieces inboard of the bolts on the bottom of the strut seem to be pushing out at the top. Anyone else seeing this on a stock or leveled truck?
Also, there seems to be a contact point between the spindle and bottom control arm. Think its just a steering stop but wanted to double check that as well.
Spoke with a ready lift tech and he said steering stop seemed normal but the bottom strut issue might be a problem. One of the other techs he had look at the pictures said it was completely normal.
Any input is appreciated.
I have a rough country 2" level kit still new in box that I would like to sell. Bought it before reading about all the work involved and just really don't want to mess with it. I'm asking $50 shipped. PAYPAL would be an acceptable form of payment.
If interested just PM me.
Thanks
Okay, here's a question that might seem repetitive! Is anyone running 275/65/20 Toyo Open Country MTs on the original all terrain wheels with the RCX 2.5 level kit? I looked thoroughly before posting and couldn't find any pictures. I did see some running the same size tire but in the all terrain tire not the MT. I wonder if they will rub a lot more than the ATs due to the more aggressive tread. I am scheduled to get my tires installed tomorrow so i am hoping someone has some pictures and info on the setup. If not i might have to play it safe and go with the 33s.
My TGC kit included new nuts, bolts and washers. IDK if I'd feel comfortable with using the stock clamp nut with a spacer or even running stock clamp nut with no spacer for that matter. Seems like it could be an easy point of failure.
I would grab a set of grade 8 or 10 (can't remember which they were) nuts, bolts and washers and replace all the stock stuff just for piece of mind.
The hardware that came in my kit was from Fastenal
Edited by Full Lock
With a rough country 2" up front and 1" block in the back will goodyear duratrac 285/60r20 fit with no rubbing?
Picking up a 2014 Silverado 1500 CC SB 4x4 this week. It has the stock 20s and I'm putting 275/65s toyo mts on it. Would like it to have a slight rake. 2.25" will get me there? 2.5" would be completely level right?
I sit level 39" front 39" rear with readylift 2.25 but im on 285/45r22
different brands vary in height.
Edited by scoobyd3w
Scooby, did your front end come up exactly 2.25"? Just trying to find out if the actual number is the actual lift. If so I guess a 2" would give me the slight rake I'm looking for.
Will both of these work on 2014 1500 all terrain with a 2" RC leveling kit?
Goodyear duratrac
285/60r20
305/55r20
Anyone currenty running one of these setups?
285/60R20's will work but the 305's will rub with just a leveling kit.
Before the level the mechanic measured from the bottom of the fender well to the ground and the front measured 37" and the rear was 39"
After the readylift 2.25 Part# 66-3085 the front fender measures an almost exact 39" depending how eye level you look :freak:
After install did an alignment and the truck feels great without sacrificing any ride quality!! hope this helps..
If you still want the rake look you might try the 2.25 level with a 1" block in the rear...
Edited by scoobyd3w
Well the readylift 2.25 front level kit is installed, and a 3" block on the back...Like the rake plus I tow a boat, sled and quad so needed it for sag. Anywho looking at beefing up the tires a little. Looking at nitto terra grapplers or cooper zeon ltz. Looking at 305 50 20...Thinking they should work by size calculator but any experience would help if you would like to chime in!
Would like to see some pics please. I have 2.5" RC lift and thinking about installing 3" block to gain some rake, did you use shock extensions?
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
