Don't do 4" of level. Had that in my old truck.. Just no.
Ok. Thanks Grey. But what about a 4in Suspension? I like the looks of the Fabtech one. If you visit there website, It'd be the one up from the basic system with the uca's. I know little about lifts, so would appreciate your input.
Sent from Tapashit
the only "suspension" lift fabtech has for our trucks is the 6" The 4" is still only a big leveling kit. Unless you have to cut the crossmember for a subframe kit, its just a big level. The only true 4" suspension lifts are the zone, bds and ranch 4" kits.
There is no difference that I know of, no. The only thing would be if it has aluminum control arms. But I think they all do now, unlike older models.
I think all the z71's/all terrains have the aluminum arms. Which means the spindle and tierod mounts are a little different than the 07-13 (someone corect me if im wrong) but my 4x4 high country has steel (black) arms so i have the same suspension as the 07-13 do. they all use the same leveling kit, just different sub-frame lift kits
Edited by GreyGhostZ71
Okay well that narrows it down. Mine is an All Terrain, and has the aluminum ones.
If you do a lift kit, just make sure you pick the one for the aluminum suspension. If you do a leveling kit, you can do any of them. Also, if you change the Ucas make sure you specify you have aluminum arms.
Sent from Tapashit
Gotcha. Thanks for the help!
What's your tire/wheel set-up?
The tires are Atturo Trail Blade 275/65/18 and the wheels are Strada Off Road Monster Wheels 18x9 with a 0 offset, The tires stick about 1/2" out of the fenders.
My update: RC 2.5, Larger rear Block from RC and just had GY Durtrac 275/65R20's installed. Not rubs just had to up back inner liner with cable tie.
2014 #1
Edited by MR. DRAG SLEDDER
2014 Z71
Just wondering if I get the RC 2.5 leveling kit, this will be just to level the front even with the back correct?
It's not an actual suspension lift?
Also, if I keep the 18's - I assume I need to go with a 275/70/18?
Thanks in advance.
2014 Z71
Thanks in advance.
If you put the block that come with the kit you'll have rake again, but it's not an actual suspension lift.
As for the tires, idk that one lol
Sent from Tapashit
No problem
Sent from Tapashit
2014 Z71
Thanks in advance.
RC 2.5 comes with rear blocks, which you can use or not use depending on if you want rake or want it leveled.
As for the tire size could go tall/skinny like a 275/70r18, or a bit shorter and wider like a 285/65r18. Really just depends on the look you want for the truck.
2014 Z71
Thanks in advance.
If you go with the front 2.5" level only, it will be completely level or very close.
If you want to see what your truck would look like with a 2.5" front level only and 275/70/18 on those wheels, just look at my gallery as it is exactly what I'm running right now.
SBC, that looks great.
How's the ride?
I see you're from Houston as I am.
The one thing I worried about going too high;
the parking garages in Houston.
The ride is definitely "firmer". I don't want to say rougher as it still rides quite well, but it's not as forgiving as stock.
I don't think parking garages are an issue with just the level, although I haven't been in one since I put the level on. But I don't think it's any taller than an F-250 4x4 and those seem to fit (barely).
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
