Has anyone had any high pitched "squeak" sounds when going over bumps after installing the 2.5" RC level? It started happening after the first oil change at the dealership. It's a strange sound but it happens when I hit bumps on the road, sounds like it's coming from the passenger's side.
If you think it's coming from the level kit take off the tire, loosen and then retighten everything. Check the spacers on top and bottom of the strut.
Edit: make sure your lower spacer bolt isn't hitting the CV shaft.
Edited by 14LTZZ71
Some kits have a 2" spacer for the top and some have a 2" for the bottom. Witch method would put less stress on the ball joints?
I have an appointment at 4 wheel parts to have the Pro-Comp 2.25 " leveling kit installed. Both spring and strut spacers, alignment and labor for 465.00 OTD.
Is that a decent deal or a hold-up?
most leveling kits will run about 200 bucks and another 70-90 for an alignment so spending another 180-200 on install isn't to bad if you don't want to do it yourself, takes 2-3 hours to put it in
This store itemized it as 180.00 for the Pro Comp kit (it's 145.00 w shipping on Amazon). 150.00 for alignment and 100.00 for labor. Add tax and it's 465.00, plus they are a VERY reputable shop here, so if I need service, I expect they will take care of it.
Thanks for the input.
Edited by austingta
I installed mine in the garage last weekend. I'm definitely not a mechanic but I like to work on stuff. I have a decent set of tools. The most involved project I've ever done to a vehicle is pads and rotors. That being said, I probably wouldn't do it again.
Austingta. That's exactly what I had done. I paid about that amount up here in Canada. It sure makes the truck look nice. I had some people ask me if it was a 3/4 ton, it looked so good.
I currently have a 4" suspension and 1.5" body lift and am rolling on 35's. My question is. Can I ditch the 4" lift and replace it with the Rough Country 2.5" leveling kit and still use my 35's till they wear out?
35x12.5x20's(18)? what wheel size and offset? What tire specifically as 35's can be 34.5 and up. I'm mostly curious myself as I plan on the 2.5 RC and 1.5 body lift. But this info will be needed for determination.
As TexasHusker stated the exact tire/wheel info will be a huge determining factor. I plan to go with 35's or really big 34's on my stock 18" z71 wheels with the lift set up you are wanting.
What kind of 4" do you have and why don't you want it anymore? Message me if your going to sell it
So those are 34.9" x 12.2" Do they bulge out a little being on a 9" rim? That info should give some more knowledgeable people some idea if they'll fit. I'm pulling for you though as I'd like to run some 35's on your intended setup.
I looked and no they do not look to bad for being a 12.2 in tire on a 9 in rim.
Nice work. I also used an aluminum spacer kit from ebay for my level. Installed and had alignment done. Be sure you don't skip the alignment.
