Has anyone had any high pitched "squeak" sounds when going over bumps after installing the 2.5" RC level? It started happening after the first oil change at the dealership. It's a strange sound but it happens when I hit bumps on the road, sounds like it's coming from the passenger's side.
If you think it's coming from the level kit take off the tire, loosen and then retighten everything. Check the spacers on top and bottom of the strut.
Edit: make sure your lower spacer bolt isn't hitting the CV shaft.
Edited by 14LTZZ71
Some kits have a 2" spacer for the top and some have a 2" for the bottom. Witch method would put less stress on the ball joints?
I have an appointment at 4 wheel parts to have the Pro-Comp 2.25 " leveling kit installed. Both spring and strut spacers, alignment and labor for 465.00 OTD.
Is that a decent deal or a hold-up?
most leveling kits will run about 200 bucks and another 70-90 for an alignment so spending another 180-200 on install isn't to bad if you don't want to do it yourself, takes 2-3 hours to put it in
This store itemized it as 180.00 for the Pro Comp kit (it's 145.00 w shipping on Amazon). 150.00 for alignment and 100.00 for labor. Add tax and it's 465.00, plus they are a VERY reputable shop here, so if I need service, I expect they will take care of it.
Thanks for the input.
Edited by austingta
I installed mine in the garage last weekend. I'm definitely not a mechanic but I like to work on stuff. I have a decent set of tools. The most involved project I've ever done to a vehicle is pads and rotors. That being said, I probably wouldn't do it again.
Austingta. That's exactly what I had done. I paid about that amount up here in Canada. It sure makes the truck look nice. I had some people ask me if it was a 3/4 ton, it looked so good.
I currently have a 4" suspension and 1.5" body lift and am rolling on 35's. My question is. Can I ditch the 4" lift and replace it with the Rough Country 2.5" leveling kit and still use my 35's till they wear out?
35x12.5x20's(18)? what wheel size and offset? What tire specifically as 35's can be 34.5 and up. I'm mostly curious myself as I plan on the 2.5 RC and 1.5 body lift. But this info will be needed for determination.
As TexasHusker stated the exact tire/wheel info will be a huge determining factor. I plan to go with 35's or really big 34's on my stock 18" z71 wheels with the lift set up you are wanting.
What kind of 4" do you have and why don't you want it anymore? Message me if your going to sell it
So those are 34.9" x 12.2" Do they bulge out a little being on a 9" rim? That info should give some more knowledgeable people some idea if they'll fit. I'm pulling for you though as I'd like to run some 35's on your intended setup.
I looked and no they do not look to bad for being a 12.2 in tire on a 9 in rim.
Nice work. I also used an aluminum spacer kit from ebay for my level. Installed and had alignment done. Be sure you don't skip the alignment.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
