Just go look. My truck hasn't arrived so I ordered the aluminum one and if the bolts are to long I'll grind them down a bit only 10 mm difference in length
I know I'm going to sound dumb, but I have a 14 Z71 Silverado and how do I know if I have aluminum or stell a-arms so I know which kit to order?
alluminum silver steel is black
Does anyone know if it is feasible to go 22" wheels with all terrain tires and a leveling kit on a 2014 Sierra SLT?
The only thing that would be affected by adding a leveling kit would be your camber and caster, which means you would maybe feel a bit squirly and have some darting on the highway.
Actually, with all the talk about ball joint wear, I thought perhaps so; however, it turns out that the only thing affected was the toe-in. Who knew?!?!
smaller%20alignment.jpg?psid=1
Camber definitely gets affected you can visually see it with spacer levels. The problem is that "spec" is a wide range and as long as it shows green on the computer they won't touch it.
Edit. I see your camber is negative that's odd I would have assumed positive.
Edited by projectsummit
The best way to tell is to use a magnet. If it sticks they're steel. If not, aluminum. There's no way to know if the factory suddenly starts painting the aluminum arms.
So I installed my MotoFab 1.5 level kit, now to see of I can fit 285/70 17 tires on factory wheels under there...
Interested to know if u can also
I'm installing a motofab ebay 1.5" level this week too, did it affect the ride quality at all?
Nope, rides like factory. I put mine on will 300 miles on my truck. YMMV
Me too!
I find that the 2" level makes the truck look nose high even the the wheel wells measure to be level. 1.5" I think will be perfect, it will have the same rake as a 2.5" level that comes with a block for the rear.
I have contacs at my local NTB, after work I'm going to stop by and see what they say, they have a 285/70 17 tire in stock, he wants to look and see if it will fit for me...
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,021 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
